Forced induction cam ? Thompson engines ,Huron speed,tick performance come in!
Old 03-01-2013, 02:30 AM
mightybird's Avatar
Default Forced induction cam ? Thompson engines ,Huron speed,tick performance come in!
Currently having a engine built that will handle my power needs to 18 lbs of boost I will be using prc 1.0 heads they They are ls6 castings ! 5.7 346 dimond pistons -2cc is being used and plan to use stock ls1 Mls gasket with studs ! I have a cam card here
Old 03-01-2013, 06:39 AM
SMOKNSS's Avatar
Are you asking about those people spec'ing you a cam? I ask because you say you have a "cam card" but nothing is there.
I don't think I have seen Thompson Engines mentioned on here before, but I know Huron Speed sells Tick Performance cams. It would probably be alot easier to call Martin@Tick or the guy at Thompson and see what they say.
Old 03-01-2013, 07:13 AM
LS1Tech Sponsor
hellbents10's Avatar
What is wrong with the engine builder getting the correct cam for you?
Old 03-01-2013, 12:32 PM
mightybird's Avatar
my plan here was to have me Thompson and tick come up with a cam based on the engine build !
Old 03-01-2013, 05:25 PM
PewterZCar's Avatar
what are your power needs? 18lbs of boost isn't a power need... is it?
If you ask three guys to run 18lbs of boost you are going to get 3 different numbers.
Old 03-01-2013, 05:32 PM
MUSTANGBRKR02's Avatar
Exactly
18lbs on a TC78 is going to be a little less than say 18lbs on a S488 for example.
Old 03-01-2013, 05:51 PM
Sales@Tick's Avatar
What are you wanting to know or have done?
Old 03-02-2013, 08:48 AM
PewterZCar's Avatar
Originally Posted by MUSTANGBRKR02
Exactly
different cams, different compression, etc. there are a million different variables that would control how much power a car makes at 18lbs.
For example my car at 7lbs is making as much power as many cars at 12lbs on this site.
Old 03-02-2013, 11:17 AM
mightybird's Avatar
Compression will be 10.4 with a ls3 gasket. Power 675 to 700 sounds exciting ! Martin I sent you a pm!
Old 03-02-2013, 11:20 AM
mightybird's Avatar
S488 does it have a 3 inch vband for the down pipe ? Who makes it ?
Old 03-02-2013, 11:27 AM
mightybird's Avatar
That's a big turbo lol looked at the s400 as well nice charger!
Old 03-02-2013, 01:24 PM
Sales@Tick's Avatar
S488 has a 5" v-band IIRC.
Old 03-02-2013, 07:03 PM
mightybird's Avatar
Huron has me covered on the turbo with the proper fitment ! Pretty sure it's a 7875
Quick Reply: Forced induction cam ? Thompson engines ,Huron speed,tick performance come in!
