what solid motor mounts with Pa k member
Old 03-01-2013, 10:08 PM
Boosted Firehawk's Avatar
Default what solid motor mounts with Pa k member
is everyone using with their turbo build?
Old 03-02-2013, 11:32 AM
Hello
Old 03-02-2013, 01:22 PM
MUSTANGBRKR02's Avatar
Look at the Modular Turbo ones.
Old 03-02-2013, 02:58 PM
They r pricey and umi has some for 150ish. Idk which to get
Old 03-02-2013, 03:17 PM
I would just not use the Spohn ones.
Old 03-02-2013, 09:06 PM
I hear ya.
Old 03-02-2013, 09:33 PM
javier1730's Avatar
I'm running UMIs with bmr member, they are really nice and light weight.
Old 03-03-2013, 08:15 AM
LS1Tech Sponsor
Superman09's Avatar
PA has a solid mount that replaces the clam shell and bolts to the factory K-member mount! I can get you set-up if interested!
Jon
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 03-03-2013, 08:19 AM
I have a PA k member! It has mounts already welded to the k member.
SO if you can get me the mount I will take it. Pm me the info and I will take it.
Old 03-03-2013, 08:27 AM
LS1Tech Sponsor
Superman09's Avatar
PM Coming!
__________________
Old 03-03-2013, 02:53 PM
UMI Performance's Avatar
Hello,
If you already have motor mount stands welded to the k-member you will need mounts that bolt into them. We offer a solid lightweight aluminum mount. I posted a link below to help. If you have any questions please ask. Thanks!
www.umiperformance.com/2323
Old 03-03-2013, 04:25 PM
Taubr Unit's Avatar
I have the UMI ones on my PA kmember. Fit perfect and easy to swap.
Old 03-03-2013, 04:50 PM
Originally Posted by UMI Performance
Hello,
thanks for the link. Are they on sale at all? Do they come with all the bolts to bolt them to the engine and and a through bolt
Looks easy I just dont know which to get
Old 03-03-2013, 05:15 PM
Taubr Unit's Avatar
UMI hands down. Very simple swap.
Old 03-03-2013, 05:19 PM
bigdog7373's Avatar
Why do you want solid? Is it a race car? The vibrations will drive you nuts if you drive it a lot. A good poly mount will work fine for most applications.
Old 03-03-2013, 05:58 PM
I will rarely drive it anyway.
Quick Reply: what solid motor mounts with Pa k member
