Those running a remote water pump
Old 03-03-2013, 03:11 PM
edge04's Avatar
Default Those running a remote water pump
What is your set up? I saw someone here had a radiator made by griffin and had a meizire water pump mounted to it. What kind of power is supported by a set up like that? Same cooling? I'm very tight with space so looking to go this route maybe. I also see moroso makes the adapter kit. What about the serpentine belt.I'm running f-body accessories .
Old 03-04-2013, 09:05 AM
edge04's Avatar
noone running a remote water pump?
Old 03-04-2013, 03:21 PM
lmt0705's Avatar
im running an afco radiator with a meziere pump mounted to it, its a 3 core design. this will be my first year with it though so not sure how its going to cool. ive been told it does a great job but there are no provisions for a thermostat so im a little concerned about that. i eliminated my AC and power steering also so i just have a 4 rib belt running my alternator which is also relocated.
Old 03-04-2013, 07:28 PM
edge04's Avatar
In looking at various pumps and the adapter kit, they are all -12 fittings. That seems small and has me concerned with cooling capabilities. But looks like Moroso does make everything need including remote fill and thermostat housing,
Old 03-05-2013, 07:19 PM
edge04's Avatar
So I found this thread. Only thing is no one here is running a T-stat which I assume should be a a street driven car with occasional heat needed? I know moroso make a remote t-stat housing as does meizire but looking for one with -16 ports or suppose I can put in a -12 to -16 fitting if those are made?
And wonder if there is any issues with serpentine belt routing without the WP pulley. Still going to run PS and Alt.
And maybe this would have been better posted in the conversion page lol
https://ls1tech.com/forums/drag-raci...er-pump-3.html
Old 03-05-2013, 08:13 PM
dschmittie1's Avatar
here is mine. I modified my existing griffen rad to mount the remote pump. no issues cooling my car in traffic
Old 03-05-2013, 09:38 PM
edge04's Avatar
^^^ running a t-stat?
Old 03-06-2013, 08:54 AM
No T stat
Old 03-06-2013, 10:21 AM
edge04's Avatar
starting to think that this set up wouldn't be good for a car that drives on the street (albeit nice weather only). Would need to plumb in a t-stat and T's for the heater. Lots of plumbing.
Old 03-06-2013, 10:45 AM
droksformula's Avatar
Originally Posted by dschmittie1
here is mine. I modified my existing griffen rad to mount the remote pump. no issues cooling my car in traffic.
I am going to do similar to this, but where do you run the line coming from under the rad cap on the fill can?
Old 03-06-2013, 10:49 AM
The Steam tube from the heads goes into the side of the surge tank mounted on the passanger side head. Just can't see it in that pic
Old 03-09-2013, 09:50 AM
edge04's Avatar
Does anyone know if they make a fitting that would allow you to Y the top hoses before going back to the top of the radiator? Looking for one that I can put on the top fitting of the block or come out of the thermostat.
Or is there another place to supply the heater with?
Old 04-06-2013, 05:13 PM
White Out's Avatar
Jegs has this:
http://www.jegs.com/i/JEGS+Performan...50960/10002/-1
Old 04-07-2013, 05:29 PM
n2o4myfix's Avatar
I used one of them pro comp 130gpm along with a 16an inlet the rest 12an, no t-stat. The motor is a stock lq4 and runs on e85, when its 60 degrees the engine temp stays around 160 driving, at a idle it never gets to a temp that registers on my gauge. I'm not proud that I used a off brand pump, but its what I could afford at the time.
Old 04-07-2013, 05:51 PM
MUSTANGBRKR02's Avatar
Looks good. I plan on doing this after i get back.
Quick Reply: Those running a remote water pump
