stock 5.3 with turbo help
Old 03-05-2013, 06:43 AM
64chevy's Avatar
Default stock 5.3 with turbo help
I would like to first say i am new here and love spending hours looking at all the builds. You guys are amazing at what you can build and tune. I want to say thank you first and foremost for any info.
I am looking at doing a comepletely stock 5.3 with a single turbo in my 64 Chevy II. Is it feaseable to do it all with tranny 4l80 for under $3000. Also what all would i need? I am very good a building and metalwork so no problem there. Thank you for any help
Old 03-05-2013, 07:36 AM
conor.davis's Avatar
https://ls1tech.com/forums/forced-in...induction.html
Did you read that sticky at the top?
It's a good start. I've seen people make more with less than $3k so I'd say it is very possible... But it's just how you go about doing it
Old 03-06-2013, 10:07 PM
LS1NOVA's Avatar
Sure it can be done but spend very carefully. What all would you need? Thats a pretty vague question but Ill try.
$200 5.3
At least a set of valvesprings
Ebay head studs, replaced one at a time
Used On3 76, Turbonetics TC76, etc.
80lb hi imp injectors
budget PTC converter
used 80E with Transgo HD2 kit or mod it to dual feed direct clutches
mod a stock truck harness and ecm (LT1swap.com)
couple walbro 255's
Old 03-07-2013, 06:46 AM
64chevy's Avatar
$200 5.3
couple walbro 255's
Thank you. I know i kind of have a vague description. I think i will retain my built th400 as i have a 3.08 with a locker. So as i have read, still get good gas mileage. That will save me some money. What brand popoff and wastegate would i need, or whats best bang for my buck.
Thanks again. Brandon
Old 03-07-2013, 06:59 AM
69-chvl's Avatar
Your gonna have to use used stuff and/or china equip.
A good new w/g is like 300.00, BOV 250-300, injectors 300.00+. 1000.00 right there.
So far I purchased a 96 Stang and doing a basic 5.3 turbo deal. I cant see me doing this for less than 11k. This includes the price of the car, cage, and wheels, gauges - using all used stuff/china
Old 03-07-2013, 07:53 AM
LS1NOVA's Avatar
Th400 setup is good! Don't get discouraged. I did a 5.3 single 70mm swap in a guys Camaro for $5000 including my labor. The naysayers just have not smartly shopped or fell victim to the snowball effect.
I like the Precision 46mm wastegate for $315 and the china bov from Race Parts Solutions or VSracing. You could use a china 44mm gate and no blow off valve for the ultimate cheapy setup.$125 total.
Old 03-07-2013, 08:57 AM
T76s10's Avatar
I would do Ebay gt45 ($240), emusa 38mm wastegate ($55), Ebay bov ($50), Ebay intercooler ($120), ls6 springs ($60), siemens 60lb injectors ($340), ecm/harness from junkyard ($100), twin walbro 255's ($160) and then hp tuners ($500). Then get some hot/cold pipe and fuel fittings with reg and all extra little ****. So that's roughly $1525 in the list i posted and lets just say $500 in all the extra stuff you'll need. It may not be the best combo but its in your budget atleast
Old 03-07-2013, 09:34 AM
64chevy's Avatar
Thank you all for helping me out. I have heard 68,70,76 for the turbo. Which really will be best for mainly street driving. Like to be 550+. Also i have heard the Bosch 044 pump for external. I would rather go external if i could. What radiator do you need to use? Also injectors have heard 60 and 70?
Thanks guys
Old 03-07-2013, 10:31 AM
Twin turbo c5's Avatar
Yeah you can do it for that kinda money. I do it all the time. You just gotta have some friends with used turbo stuff to help you out.
Old 03-07-2013, 11:39 AM
jonahs_supra's Avatar
Im doing a similar swap in my MK3 supra
Right now I have exactly $4000 in my setup
4.8/4l60E....$650
Harness/pcm....$200
eBAY gt45....$260
42lbs injectors....$200
Aero A1000...$150
Walbro 400....$150
LS1 intake....$150
LS9 heagaskets....$100
eBAY FMIC....$80
FMIC piping....$80
Presicion 39mm wastegate....$225
Used turbosmart bov...$200
LS6 cam....$150
LS6 yellow springs....$35
Tune....$200
Assorted AN fittings/hoses....$200
TB coupler....$30
Comes to $2960
Theres a few things you dont really need but I am running. That was just a base budget
Old 03-07-2013, 01:57 PM
408COUPE's Avatar
I am about to pick a 5.3 today. Do they make a off the shelf aftermarket good piston and rod for it??
Old 03-07-2013, 10:43 PM
T76s10's Avatar
Thanks guys
i would choose the 68mm ebay gt45. its got the largest turbine of them all which is 78mm and will help keep backpressure down and make great power. the bosch 044 pump is a great choice i have one paired with a 255 and it works great. i use 3 row champion radiators because they are cheap and with a descent fan setup you will be 5-10* warmer than your t-stat which is pretty good. 60lb injectors will be good for what your power goals are. if you want some room for the future go with the siemens 80lbers.
Old 03-07-2013, 10:47 PM
T76s10's Avatar
look at texas speed. they came out with a 3.78 piston not too long ago and they have matching 6.250 rods for it also
Old 03-08-2013, 03:55 AM
64chevy's Avatar
Is it wise for me to run E85? Its easy for me to get here so thats a plus. I would assume i would need to jump up to 80lb injectors? Also i dont really need a BOV?
Thanks once again
Old 03-08-2013, 09:40 AM
T76s10's Avatar
yeah if you can run it. skinnies maxed 80lbers out at 850whp with e85 so youll be good. no u dont need one
Quick Reply: stock 5.3 with turbo help
