By show of hands. Who has
The KYTP TC78 kit and has mounted their radiators vertical using part #25241-X-Griffin (radiator). I'm about to finish up the install and now I've ran into a snag with the UICP running into the water outlet. Just curious to see if and how you guys re-ran your UICP.
You are correct sir. Upper intercooler pipe. It seems that the lower water outlet on the radiator sits in the way of the pipe. I will re-mount my intercooler and the first section of the upper pipe with its 90 degree elbow coupler and see what's what. All I did was mount the second section to the throttle body for testing. Do you have any pics or can shed some light on what you did? It would be appreciated.
Ya, that's way different than mine.
This is when Josh was building the kit.
This is from last night...test fitting a lower hose. I need the pipe to go in between the outlet and wastegate. It used to sit perfectly where the outlet is.
Here's how it sits now
Sorry for all the pics. Just trying to give an idea of my troubles.
