Anyone knife edged a divided turbo housing?
Old 03-10-2013, 05:03 PM
roswald0511's Avatar
Default Anyone knife edged a divided turbo housing?
As the title states. I am wondering if anyone has taken a divided turbo housing and filed it down to a knife edge to create less resistance when using a non divided manifold?
I would love to know if anyone has done back to back testing of this. I believe it would help boost come in faster, though it might be minimal it would still be cool to see the results.
Old 03-10-2013, 08:38 PM
HexenLord's Avatar
I've seen it done. It can help with Max power output but not necessarily spool times. If you want faster spool with a divided housing get a spool valve.
Old 03-11-2013, 01:58 AM
stangtrader's Avatar
I did it on mine,only because I used a open flange and then filled to reduce turbulence. It may make a difference but hard for me to say
Old 03-11-2013, 06:39 AM
stevieturbo's Avatar
It can certainly do no harm, but as to whether any difference would be measurable...doubtful.
Old 03-11-2013, 08:56 AM
LilJohn's Avatar
You dont knife edge it. You round it over like the leading edge of an airplane wing.
Old 03-11-2013, 10:19 AM
dirty_old_chevy's Avatar
Airfoil..... I like it.
Old 03-11-2013, 05:58 PM
Thank you to all of you for your input. I just wanted to see if anyone had any back to back results via dyno or data logs.
Maybe I will just have to be the test mule. Thanks again.
Quick Reply: Anyone knife edged a divided turbo housing?
