What do I need fuel system for 1000HP s480 Turbo
Old 03-11-2013, 06:31 PM
zapp109's Avatar
Default What do I need fuel system for 1000HP s480 Turbo
Im trying to get everything together for my fuel system, here is what I already have.
95lb injectors
Edelbrock fuel rails
Aeromotive Eliminator pump
Aeromotive 13101 FPR
Aeromotive filters
(Also have Meth Kit)
This is going in my fox with a sumped tank. So first off im thinking that this fuel pressure regulator is not going to work because of the -6 return line?
Im thinking -10 lines both supply and return????? Anyone with high HP running that FPR? The instructions on the aeromotive eliminator say i should run the 13110 ... pshhh over 300 bucks for that thing.
Old 03-12-2013, 10:13 AM
Blackpanther99's Avatar
Let me ask first:
What fuel will you be using?
Old 03-12-2013, 11:56 AM
Cam72aro's Avatar
run the same regulator with -10 feed and 06 return and no problems.
Old 03-12-2013, 03:24 PM
allout06's Avatar
id sell ur aeromotive stuff and go magnafuel.
Old 03-12-2013, 03:40 PM
Trl_ws6's Avatar
2nd that. Magnafuel all the way. I have there 4303, 10 feed/return, regulator and filters.
It all falls back on what fuel you are using.
Old 03-12-2013, 04:55 PM
Old Geezer's Avatar
FW or RW???
Old 03-12-2013, 05:16 PM
zapp109's Avatar
Sorry should of said its 93 pump gas.
Old 03-12-2013, 06:20 PM
narfdanarf's Avatar
-6 return is fine for that pump.
Quick Reply: What do I need fuel system for 1000HP s480 Turbo
