GT45x vs S483
Old 03-15-2013, 07:25 PM
EV1LR8's Avatar
Default GT45x vs S483
Just wanting to know peoples thoughts on the two,
It will be for a 402ci, Trickflow 220cc heads, Edelbrock XP intake, TH400
Cheers Jase
Old 03-15-2013, 07:32 PM
Preston99WS6's Avatar
Cheers Jase
S483 all the way, the GT45 will choke that 402.
Old 03-15-2013, 09:04 PM
EV1LR8's Avatar
whats the flow rate difference with a T6 ?
Im in Australia and most seem to run the Garret but i think that only because there's not alot of info here or tested cars running the S483/B483
Old 03-15-2013, 11:03 PM
Didn't notice the X after the GT45 so I take back the chocking statement both are good choices I know that a cast wheel S483 is rated at 128 lb/min, the exhaust size on the BW is a little larger, Rumor has it there is a new forged compressor wheel in the works for the BW S483. In current form the turbo is capable of 1300 hp on a 400ci motor. Add a race cover and the new wheel and it will exceed the capabilities of the GT45X and probably be in the same price range.
I read somewhere the GT45X only flows around 100lb/min but I am having a hard time finding a map for it so it could be internet hearsay. So don't quote me on the flow rate.
Old 03-16-2013, 10:48 AM
rotary1307cc's Avatar
Lol he didnt even say what turbine in the 400. What if he had the 83???
The 80mm gtx45 is over 125lb/min
Old 03-16-2013, 10:04 PM
EV1LR8's Avatar
Was thinking S483 with race cover, 87mm turbine wheel with 1.10a/r T6
Can't find a supplier in oz,
Old 03-17-2013, 12:42 AM
Sales@Tick's Avatar
You need a larger turbine than a 87mm wheel for a 400c.i. anything. 96mm wheel, 1.32 A/R housing and size the down pipe, crossover and primaries correctly with a good converter and you'll be golden. 402 will spool a 96mm wheel with no problems in a hurry.
I'd go with a billet S400-83/96. At least that's my preference between the two.
Old 03-17-2013, 02:48 PM
LS1TECH Sponsor
DrTurbo's Avatar
Originally Posted by martin@tick
you need a larger turbine than a 87mm wheel for a 400c.i. Anything. 96mm wheel, 1.32 a/r housing and size the down pipe, crossover and primaries correctly with a good converter and you'll be golden. 402 will spool a 96mm wheel with no problems in a hurry.
I'd go with a billet s400-83/96. At least that's my preference between the two.
x 2..
Old 03-17-2013, 09:22 PM
EV1LR8's Avatar
Originally Posted by DrTurbo
x 2..
My only concern with going the bigger rear housing is lag
It's street driven and I thought the bigger housing my be laggy
What's a S483 worth ?
Cheers Jason
Old 03-17-2013, 09:33 PM
trust me it wont be laggy
Old 03-17-2013, 09:54 PM
LilJohn's Avatar
Lag... with a 96/1.32 and a 400 inch motor.....uhhhh yea... youll be looking at ways to calm it down so its not too stupid to drive.... Especially you cam it correctly.
As far as the whats an S483 worth question... are you asking price? Or hp capability?
Hp... 1350 ish. The billet 80 makes more power... its worth 1450-1500 ish.
Old 03-17-2013, 10:48 PM
EV1LR8's Avatar
True, asking for price and power, It seems every site I look at gives different power figures for it,
I thought the 83 was a billet wheel ? Or is that just a option ?
Cheers Jason
Old 03-17-2013, 11:04 PM
LilJohn's Avatar
Theres both.
The billet 80mm im speaking about isnt a borg wheel...its a custom designed piece for that turbo.
It comes from Forced inductions.
Old 03-18-2013, 01:59 AM
EV1LR8's Avatar
Theres both.
ok ive seen a few shops do custom design's of the borg turbos,
i would of thought the 82/83.. billet turbos would make more then a 80mm billet
Old 03-18-2013, 05:54 PM
Sales@Tick's Avatar
Lag will be nonexistent on a 402 with that turbine wheel and housing combination.
Old 03-18-2013, 10:00 PM
Texhotrod593's Avatar
X3!!
That thing will light up very fast on a 400+ ci
Old 03-18-2013, 10:39 PM
LS1TECH Sponsor
DrTurbo's Avatar
Our new billet 83mm HO wheel is almost ready as well. Should make some pretty stupid power. We are also working on a new turbine wheel for the S400 as well. 100mm's of turbine goodness should free some things up.
Old 03-19-2013, 03:48 AM
EV1LR8's Avatar
Nice, Whats the price for the 80mm unit and the expected price and power figure of the 83mm unit ?
Cheers Jason
Old 03-19-2013, 04:39 PM
Sales@Tick's Avatar
WHAT!?!?!?! You sneaky devil!!! I need one for testing purposes!!!
Old 05-24-2013, 05:35 AM
EV1LR8's Avatar
Has the 83mm HO wheel been released yet mate ?
Quick Reply: GT45x vs S483
