60lb injectors
Old 03-16-2013, 12:13 PM
01transampower's Avatar
Default 60lb injectors
Where have you guys maxed your 60lb injectors out? power and boost wise?
Old 03-16-2013, 04:30 PM
Tally TransAm's Avatar
they should be good for +/- 700-750 with an adequate fuel system.
im maxing mine at just over 600 but thats cause im on a stock line system with no boost ref regulator
Old 03-16-2013, 05:32 PM
I'm going to do a full fuel system with -8 feed stock feed as a return a walbro 400 and a regulator with fuel rails.
Does that seem adequate?
Old 03-16-2013, 06:09 PM
turbocreeper's Avatar
600whp or flywheel? im looking for 60s but my goal is 650rwhp. should i be looking for bigger?
Old 03-16-2013, 07:05 PM
last dyno pull was 610 rwhp on a mustang dyno seeing 95% duty cycle. honestly i think its making a little more than that as its trapping 3-4 mph faster now than when it was consistently pulling 580-590 rwhp. problem isnt the injectors though
Old 03-16-2013, 09:31 PM
My concern was more as will 60's with the fuel system I plan to run be big enough?
Old 03-16-2013, 09:50 PM
big enough for what? you havent mentioned a power level or et/mph target.
Old 03-16-2013, 11:01 PM
Boostfed's Avatar
I would just do 80# injectors if I were you. It gives you more room to grow instead of being so limited and there really isnt much of a price difference between the 60# and 80# injectors, so you might as well just get the 80's.
Old 03-17-2013, 03:06 AM
My power goal is the 700 range. Plus or minus. And I know its good to have room to grow but this is an end goal for my car. I don't plan to go bigger. I set a limit for myself and I wanna keep it.
Old 03-17-2013, 07:26 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
I need to do some work on my fuel setup as well. I have twin 255's in tank, run through the factory line to a set of custom fuel rails and 60# injectors. I know I'm already at about as far as I can go with this setup. I guess it's time I step up to a dedicated line and regulator as well.
I'm running~15psi of boost and seeing north of 85% idc, but I'm also spraying a good bit of methanol/water.
Old 03-17-2013, 08:07 AM
no boost ref regulator either? have you had it on the dyno or track mph? curious as to how we compare, i was expecting more outta mine but it makes sense
Old 03-17-2013, 09:28 AM
Boostfed's Avatar
I said that at one time as well. Now I just came to terms that my car will never be fast enough or look good enough lol. I understand you have an end goal, but why not just spend a few more dollars, literally, to get something you know will work instead of guessing and hoping the 60# injectors work.
Old 03-17-2013, 11:10 AM
UNDER PRESSURE MOD
No boost referenced regulator here. No dyno or track times either, just a fun street car. I need to toss it on a dyno just to make certain my tune is good and get a point of reference for future plans.
Old 03-17-2013, 11:42 AM
This is very true. You do make a good point about that. And 80's only cost a little more. If I do go bigger I would have them but I wasn't sure about the the injectors since I am new to the forced induction world.
Old 03-17-2013, 05:23 PM
Boostfed's Avatar
You can find good deals on ebay. Just make sure you get them with the right connector.
Old 03-17-2013, 07:41 PM
Thats where ill look. I was going to go with Siemens Deka 60lbs. What do you guys recommend for 80's?
Quick Reply: 60lb injectors
