Whats the Correct catch can routing for a front mounted single?
Im almost done with my T4 Single kit. Setup is-
HS single kit
Standard truck mani kit, turbo is a PT7675, PT 46mm wastegate and RPS 50mm bov , want to run 10-11psi for now.
Brute speed blower cam
Will be spraying meth
All supporting mods
My question is what catch can should I go with and what is the correct way to route all the lines to the can. I want to have proper crank case venting here.
I've seen so many different ways and I only want to do this once.
HS single kit
All supporting mods
I used the saiku michi dual catch cans. I know there are alot of guys that vent the catch cans, but I recirculated mine and haven't noticed much if any blow by. The below is the diagram I run and the catch can I used
http://www.saikoumichi.com/Stage1_LS1_page.html
Just sub the supercharger with the compressor side of the turbo
I don't think there is an inherient gain in running the duals outside of just more capacity to catch oil vapor. Had I known MM was doing those catch cans when I bought mine I would have probably picked up his. It's a badass catchcan. The saiku michi works good though. Have no issues and draining it is pretty easy.
