What turbos for a street driven 427 6 speed car.
Old 03-22-2013, 09:34 PM
fastcars95's Avatar
Default What turbos for a street driven 427 6 speed car.
I'm looking for advise on what turbos to order for a 427 99% street driven 6 speed car. Not looking to make 1200whp or anything too crazy.
800 ish whp would be a nice for street driving. Maybe as much as 1000 with the boost set to kill for the track.
I'd like the boost to come on no later then 3000rpm.
The two turbo I've been looking at are the turbonetics 6162s and the 6665s both .81AR.
I know they are a little small but I dont want to have to wait for them to come on and I dont want to have to rev the motor to the moon.
The motor is forged with 9.0 to 1 CR. The heads flow just shy of 400cfm.
Any other turbos I should look at.
Old 03-22-2013, 11:24 PM
westtexasbuff's Avatar
377ci with a 6 speed here, running billet Comp 6767s. No dyno yet, but I plan on making 1000ish.
Old 03-22-2013, 11:28 PM
fastcars95's Avatar
I forgot the mention the turbos need to be t4s with 3 inch vband exhaust. It's a kytp twin kit.
Old 03-22-2013, 11:33 PM
qqwqeqwrqwqtq's Avatar
GT35R's with 1.06 a/r exhaust housing will meet your goals perfectly.
Old 03-22-2013, 11:36 PM
For twin T4 I would use PT 6266's .81 a/r.
Very fast response while easily capable of exceeding your power goal.
Old 03-23-2013, 09:13 AM
2000RATA's Avatar
378 inch here with TR6060 trans and t-netics 6165 .68 A/R made 950 rwhp at 14 psi. Not even trying.
Old 03-23-2013, 09:28 AM
fastcars95's Avatar
Thats what I like to here. I would love to run around on only 10-12lbs and make that kind of power.
The .68 a/r might be alittle small for my set-up. What rpm do you make full boost ?
I'm leaning towards the 6665s. I'm just not sure if the turbine size will cause back pressure issues.
Anyone know if turbonetics makes a 6669 ? or something along that line.
I'm trying to stay away from 70mm or larger turbos. Too much power for what I want and I dont want the lag that comes along turbos that size.
Old 03-23-2013, 09:56 AM
2000RATA's Avatar
Do this. But use the t-netics. The customer support and warranty seems to be alot more friendly.
As far as when the boost is on full it's around 3000 or so. It just depends on what gear your in and what rpm you hit it at.
LS1TECH Sponsor
DrTurbo's Avatar
We carry Turbonetics 6668's. That is their largest version other then moving up to 75mm turbines. You can also go with the BW 366/73 as well or the BW 366/68 also. Both of those will make ridiculous power also. With the billet ETR wheel we are getting 900+ hp out of the 66/73.
Old 03-23-2013, 11:17 AM
Tiago's Avatar
or even the 0.82 housing....hit even harder.
Old 03-23-2013, 02:13 PM
fastcars95's Avatar
Will the 6668s light-up right away. My big concern is lag. I'd like to run the smallest turbos possible without creating too much back pressure. I'm not worried about making much over 1000hp. This is a street car
Old 03-23-2013, 02:40 PM
Blackpanther99's Avatar
PT 6266s will work real good IMO. You should make them spool with no issues.
Old 03-23-2013, 03:40 PM
LS1TECH Sponsor
DrTurbo's Avatar
For spool up any of the 62 or 63 mm units will easily make 1000hp and all of them will spool well.
Old 03-23-2013, 09:02 PM
fastcars95's Avatar
I'm leaning toward the 6265s just need to decide on a A/R.
I think they will spool quick and make the power I want.
Old 03-24-2013, 08:37 AM
I think they come in a .82 housing.
Old 03-24-2013, 02:21 PM
gnx7's Avatar
I've been in the supercar Ford GT with (2) GT35R's and spool up was pretty much instantaneous. In the lower gears (1-2) you would want boost by gear or the car would be worthless to drive on anything other than slicks. In 3rd/4th gear the car pulled like a freight train.
Old 03-24-2013, 02:51 PM
fastcars95's Avatar
What's the wheel sizes on a gt35r.
Old 03-28-2013, 10:51 AM
fastcars95's Avatar
Still looking for ideas. I'd like to order these turbos soon. Leaning towards Turbonetics becasue of the price. I want to feel comfortable that I'm going to choose the perfect turbos
Old 03-28-2013, 11:28 AM
cmac06's Avatar
I went with GTX3076R's. I wanted it to be most efficient under normal driving conditions. We'll see how it pans out. 62mm is ideal based on talking to several companies though.
Old 03-28-2013, 12:06 PM
fastcars95's Avatar
Those are just to expensive right now. That would eat up my cash for a 9 inch. They are right around twice the price of the turbonetics units.
Quick Reply: What turbos for a street driven 427 6 speed car.
