Welding aluminum tubing with Alumiweld...
Old 03-25-2013, 07:14 AM
mightyquickz28's Avatar
Default Welding aluminum tubing with Alumiweld...
Day 1:
I'm finishing up installing my new turbo/hotside which required rerouting of both the air filter tract and the turbo outlet to the intercooler. I had some left over 3" aluminum tubing from the original install back in '08. After trial fitting over and over and repositioning this that and the other, I finally arrived at a configuration that works. But, I only had one 90 silicone coupler and I needed two. Dang it... wait.. didn't I see a youtube about some aluminum sticks that they welded a hole in a thin a** coke can? I have a spare 3" "J" joint of the intercooler piping. I'll cut an elbow out of it.
So, I went and found that video and they used propane. Hmmm.. So I went and bought some alumiweld rods and got out the old Benzomatic propane along with some scrap 3" aluminum. Following the instructions, it took a fair (ie: too long for my impatient a**) amount of time to get to the 'melting point'(700 degrees) of the Alumiweld. This is because the thin gauge and the quick heat dissipation properties of Aluminum make it difficult for a marginal heat source such as Propane to reach/maintain the proper heat soak. Basically the way Alumiweld works is you heat the aluminum stock, then pull away the flame and wipe the Alumiweld stick on the hot surface. If the aluminum is hot enough, the Alumiweld will melt like a wax candle into the joint. Just keep rotating the flame over the surface to maintain the heat as you keep wiping the Alumiweld rod on the joint. Let it cool naturally(air cool) before using it.
So, I went to Lowes and bought a MAP/Pro TS8000 which has a larger tip and the inherently higher heat potential. I went back to my scrap and tested again. Ah, yes! Much better! The rod flows right into the joint and is strong (not bad looking either!) So, I’ll tackle the ‘real’ piping after I get back home (on the road right now at a client site). I’ll take some pics in case some of you other DIY’s are interested. I hope to weld some of the other connections to reduce the total amount of couplers I have. Those stinking things blow off at the most unwanted times.
Of course I'll pressure test it before 'going live' with it.
Day 2:
A fellow Fbud mentioned about the Alumiwelds tendency to flow too much once heated and that a tube circumference would present such a problem. I countered...
"Kevin,
Yeah, that aspect you mention of the "melted or not" was referenced in an article I found on the 'net. But they had a solution suggestion too. By 'belling' the opening on one, so that the other pipe could be seated inside the bell lip, you could create a 'cup' of sorts to retain the molten alumiweld. I think if I bell mouth the receiver and then position both pipes in a jig so that the pipes openings are horizontal, I can retain the molten weld. I'm hoping to get to this today or tomorrow. Spring my ***... this weather here in Upstate NY blows(no pun intended). Still snowing, still cold, still windy... I don't have a garage but I have a basement where I can try this.
On the SS brush and cleanliness, yes. I tried with a new brass brush I had but the molten weld/filler wouldn't stick. Vigorous brushing with the new SS brush before the welding worked perfectly.
I have my elbows already cut but I have to mock it up on the car while lying in the (alternately) mud/snow on my mat, then mark it up with a sharpie. Then I'll take it off, set it up with tack welds, try in the car and if all is still aligned, weld it fully. "
Day 3:
Well, I took some more scrap 3" and, using a crescent wrench on it's tip, tightened down on the edge of one pipe bent it outwards, all around the perimeter. Then I SS brushed both pieces I was joining. Then, I put the bell mouthed pipe in a vise so it would hold the pipe vertical, the cut/bell mouthed edge on tope, horizontal. I then put the other piece of pipe on top of the bell mouthed edge and started heating both pieces with the MAPP set on the lowest flame it could sustain. After the aluminum piping reached the proper temperature, the Alumiweld started flowing. I walked the flame and the alumimeld around till I completed the circumference. I let it cool fully and then tried to pull it apart. NO way! Strong and sealed. I got my trial fitting done and all is ready to weld up tomorrow.
Day 4:
Once again, a friend offered advice. "Why don't you get one of those cheap pipe expanders instead of using a crescent wrench?"
My response: "Hi, yeah. I already had one of those. Unfortunately, unless you've got it clamped in a vise (not good for thin gauge aluminum), it's just going to turn with the expander. I'm working on fabrication of a tool where I can use one of those expanders with a hydraulic bottle jack so that the jack can just push against the bevel in the middle and force the expander outward rather than that near useless threaded rod. I've torn up about 3 of those expanders trying to expand 3" mild steel exhaust tubing to 3 1/4" for a slip joint. The threads start stripping and it doesn't even expand the tube! I've drawn up the plans for the chassis to put the expander and the bottle jack within. "
Day 5:
Trying to upload the pictures from my phone now guys.
It was a success, I can tell you that.
Notes:
You CAN use the plain jane Benzomatic propane. In fact, the MAPP, even on low setting, is a bit too hot. The 'cupping' of the receiver tube works great and I recommend either that or expanding for a slip joint type fit. The finished weld is strong. I don't know what 'grade' of aluminum this alumiweld is but like you've heard and read, it's a LOT stronger than the aluminum tubing. It takes a serious grinder to get thru to. The first tubing I welded was the piping going from the turbo outlet. It goes down and then 90's to the front of the car then, 90's off to the left side of the car to meet the intercoolers routing. This is the one I cupped. After deflecting the perimeter of one of the elbows, SS wire brushing and marking both pieces for alignment while on the turbo, I gently clamped it in a vise in an orientation where the cupped surface would be horizontal, level. I then put the other elbow in the cup, flush surfaces, and with my alignment marks placed correctly. Using some welding rods as props to hold the top elbow in place, I started heating the pipes. Once the tubing reached approx 700 degrees, the alumiweld started to melt as I wiped it across the joint. Letting it flow, I walked the flame and the alumiweld around the perimeter till it was completely welded. After a few minutes, I pulled it off the vise and set it on the porch to cool for several minutes. I then got the 4" airfilter to turbo piping out, SS brushed and clamped in the vise. I thought on this piece, I'd just see if I could get the alumiweld to weld without the cupping exercise. Just for grins. It worked too but you really have to work the flame carefully. If you let it stay in one place too long, the alumiweld puddle will just drip off and hit the floor. Once that was finished, I took it outside to let it cool and started examining the first peice. I wanted to see if it had sealed totally. I took it inside to the kitchen, put some soapy water on the joint, sealed one end with my hand and putting my mouth over the other end, blew into it as hard as I could. Drat..a few pinholes. I wiped it down with brake cleaner, SS brushed it and went after the holes but tried laying it on its side so I could just address the pinhole I found. Bad idea with MAPP. This is where I found out it can get too hot. Even though I'd turned the flame down low, it melted an edge of the actual aluminum and made a 3/8" hole in the pipe. Phock! Killing the MAPP and pulling out the old Propane, I covered the hole I'd created. Whew...
This created and blob of the alumiweld that, once cooled, I ground down. This is where I found that the hardness of the cooled alumiweld is so tough. I tried pulling apart the pipes with my bare hands. Not happening. I tried twisting the elbows apart. Nuh uh... can't.
I had to weld another piece of straight on to my existing straight to have enough reach to make it to the intercooler. The propane did the job fine and the first time. So, now all the intercooler/air filter stuff is on the car and bolted up! All that's left now is wiring the fans (using the stock fans as pushers) and welding up a small section from the down pipe to the Borla intermediate and the tough stuff is done!
The elbows before I started....
Showing how flush the cuts are...
Starting the 'belling'/'cupping' of one of the pipes...
Showing the insertion of one tube into the others 'cup'...
The welded piece...
Old 03-25-2013, 08:14 AM
Blackpanther99's Avatar
Great write up sir. Good work
Old 03-25-2013, 08:16 AM
roninsonic's Avatar
That's pretty damned trick. Kudos, man. Glad that worked for you.
Old 03-25-2013, 08:36 AM
club_xcursion's Avatar
awesome for guys who dont have a tig machine! id like to see the pressure test.
Old 03-25-2013, 09:23 AM
oange ss's Avatar
that stuff works good in a pinch, as you found out cleanliness is key, use a dedicated stainless brush for aluminum, acetone helps cut any grease/oil residue
Old 03-25-2013, 09:40 AM
stevieturbo's Avatar
It's basically just brazing the parts together, it should be sturdy
Old 03-25-2013, 10:25 AM
Reject's Avatar
pretty neat, have a link to the material? also minus cutting the pipes, how much time do you think you spent brazing the parts togther?
Old 03-25-2013, 11:04 AM
I'm onsite for a client this week but when I get back to the house, I'll set that up. I, too, am interested in the pressure test. I plan on taking an unused bit of pipe, capping both ends . Then, I'll cut it in half, then alumiweld the halves back together. Next, I'll insert a valve stem into one end. Afterwards, I'll put my air hose on it and put it up to about 20 psi to see how it holds(or lets go!)
Old 03-25-2013, 11:10 AM
It's quickly done. Just cut, SS brush, mockup/mark, heat the aluminum pipe at the site to around 700 degrees with a standard (hardward store variation Benzomatic) propane torch. Go to youtube and look up "alumiweld". There's tons of videos out there. You can get Alumiweld from Harbor Freight and welding supplies(probably a different name at the welding supply stores but same product/procedure). About $15 bucks for a tube with 8 to 10 sticks inside. Like all welding/brazing, practice on clean (SS brush and acetone) scrap before using your valuable stuff!
Old 03-25-2013, 12:44 PM
Sarg's Avatar
In for pressure test results.
Old 03-25-2013, 12:56 PM
JAX04's Avatar
Lol, i was thinking the same.
Pretty neat i suppose though.
Old 03-25-2013, 09:49 PM
LSx64Chevelle's Avatar
20psi? Do it till it pops. Lets see what the pressure threshold is.
Old 03-26-2013, 07:50 AM
Will do. (behind a shield though, lol)
Old 03-26-2013, 08:15 AM
Sarg's Avatar
Glad to hear it. I am curious if it will actually hold a good bit. Might be a good temporary solution to having to upgrade my tig welder until I can afford a better one, lol.
Old 03-26-2013, 08:34 AM
87silverbullet's Avatar
Here is the link if anybody needs it.
http://www.alumiweld.com/h2uaw.html
There is also another company that has a vid on their site that shows how strong it is. Here is the link to them.
http://durafix.com/
Old 03-26-2013, 08:36 PM
FAST LS1's Avatar
I wonder if this would work for modifying aluminum oil pans? I need to modify a GTO oil pan for my swap, but have no way of welding aluminum, plus it's thick aluminum.
Old 03-26-2013, 08:45 PM
Sarg's Avatar
Think you would have a tough time getting thick aluminum like that to get hot enough without burning a hole. That thick of aluminum is going to dissipate the heat quickly and act like a HUGE heat sink.
Old 03-26-2013, 09:11 PM
Moderator
denmah's Avatar
ive often wondered if this would work after seeing a youtube video for it!
Old 03-27-2013, 01:28 AM
NemeSS's Avatar
i used that stuff to repair a cracked sbc intake manifold. hairline cracks. and also a cracked tstat housing. that was cracked. sealed enough to not leak both items.
pretty easy to work with
Old 03-27-2013, 01:37 AM
HRHohio's Avatar
Harbor freight sells it too.
Quick Reply: Welding aluminum tubing with Alumiweld...
