High HP(1500hp+) EFI/E85 Fuel Sytems, what are you guys using? Pics welcome
Need some fuel pump, regulator, line size, line routing, fuel cell/tank ideas if anyone is willing to share their set-up. Have several customers I've already asked, just want to see some other ideas and what the majority is using. Right now I'm leaning towards a Magnafuel 4703, a Turbosmart FPR-3000 regulator along with -10 feed and -10 return lines. Want to run a y-block behind the manifold to feed both rails, then run a single line from each rail to the regulator and then return that to the tank.
On our shop car we are running a plastic tank(99-02) and it just has a -10 or -12 fitting in the bottom of the tank and the pump and dual fuel filters are mounted inline with the pump on the tank itself. We haven't had any issues with the fuel system done like this in place of a sumped portion of the tank. Granted this is a 1000rwhp nitrous car, but on gasoline not ethanol, but the single in-line pump does supply the nitrous enrichment fuel so it's being put to work and not just supplying engine fuel enrichment.
Would like to see what the big HP guys out there are running. Doesn't have to be a 1500hp set-up, but I do hope to make 1000rwhp on ethanol. Would like to not have any problems with fuel supply.
belt drive pump will supply more than you will ever need,
AND as you raise the pressure, the flow does not decrease, unlike an electric pump that loses flow as pressure increases, thus you could run your injectors at 90, even 100psi and get way more fuel out of them.
additionally, there is no amp draw, and it is dead quiet in operation
i was gonna run one of these as far as a sump goes. get rid of the barbed fitting and put on a -10an for the feed.
http://www.hellmannperformance.com/p...mann-fuel-sump
I want to drive this thing on the street, and a 2-3 gallon fuel cell on ethanol isn't going to cut it. I need to be able to drive this thing 65 miles one way to work and have enough fuel storage volume to never worry about running out of fuel. I'd love to be able to drive it there AND back home without filling up, but that may be pushing it. I'll have to see how much fuel the car drinks just driving it around.
I know most E85 guys run crazy fuel pressure because their injectors are usually sized too small for the power they're making, but I've got a set of FIC 1600cc injectors sitting here for this thing that should supply the fuel volume I need without ever having to go over 70-75psi fuel pressure while under full boost.
Bookmarked for future reference.
I've thought long and hard about a belt drive. I was very close to pulling the trigger on an Aeromotive belt drive fuel pump, but if I do a belt drive I would have to run -10 lines from the pump, back to a cell or tank in the back, then back to the engine again. That gets expensive quick. I know I could just stick a 2 or 3 gallon fuel cell up front and be done with it, but I should of laid something else out for requirements as well.
Belt Drive:
-10 from tank to pump ~15'
-10 from pump to Y for rails ~3'
-10 from Reg back to tank ~15'
Electric in rear:
-10 from tank to pump ~2'
-10 from pump to Y for rails~ 15'
-10 from reg to tank ~15'
Also, do you think going -12 from the tank to whatever pump would be beneficial?
The problem with the belt drive pump is u still need to run a small electric pump to prime the system then shut pump off after motor fires. Unless u run a small cell upfront then u you would just run a one way check valve and that would just keep pressure in then lines.
it might have cost $150 in parts. i dont *think* it would be a problem with e85.
another thing to think about is belt drive doesnt heat the fuel like an electric.
When running a electric fuel pump it is best to run a larger line into the pump. This reduces how hard the pump has to work. Electric fuel pumps are designed to push not pull. For the horse power you are looking for like 89ROC-Z suggests you would want to run a -12 from the tank to the pump then a -10 to the Y-Block. In some cases I have seen -16 from the cell to the pump.
Pathological Modifier
With a belt driven fuel pump you really need a front mounted fuel tank unless you run a cable drive that puts the pump back in the rear of the car. I ran one (not cable drive) and had issues with it breaking up on the launch. Tried everything.
Now, I run:
-12 from fuel cell to a big *** pre-filter
then -12 to the suction of a weldon 2035db
then -10 to a y-fitting to -8s
after the y, I have two 10 micron filters (trying to minimize restrictions after the pump)
Then to the rails.
From the rails, it is -8 to a big *** aeromotive regulator,
then -8 back to the cell.
in parallel with the weldon pump I have a Walbro 255HP that runs all the time. The weldon only turns on when in boost.
This system runs perfect and is nice and quiet on the street.
Will support 1200+ on E85
Now, I run:
Then to the rails.
not necessarily. i run methanol and i have a 1 quart cell, small $30 pump and used fuel solenoid for priming when it is cold, but in the summer, it starts without the primer in two cranks.
Or just buy a behind bars race cars complete fuel system with pump mounted in tank and call it a day... Best fuel system I've ever bought and installed and he's a magnafuel dealer.
Now, I run:
Then to the rails.
Now, I run:
Then to the rails.
The problem with all those big pumps...the link claims the 4703 is a 2500hp pump....then in the small print, when running n/a. There isnt any flow data to suggest how the unit performs at higher pressures.
I'd guess that at 60-70psi as would be seen with a bit of boost....it will have dropped a good 30-40% of it's flow as most of them seem to do.
It would be very helpful if they offered some flow data.
Perhaps something like that and a Bosch 044 running for normal usage like desribed above would give plenty of headroom.
That sump linked above looks tiny. Better than nothing I guess, but still tiny.
