boosted newb
Old 03-30-2013, 05:20 PM
prostreet1967's Avatar
Default boosted newb
Made swap from BBC to 5.3. The plan was to make the swap to 5.3 then put turbo in the winter but I came across a used turbo at swap meet today. Hope I didn't get ripped off.
Its a garret tv8513.
Doesnt have any play in and out but slight side to side play. Has a reman sticker and it looks like it has been run but it's not to dirty. Picked it up for 140 should i keep it or try to flip it?
Sorry if pics don't come out
Old 03-30-2013, 07:11 PM
Anti_Venom99's Avatar
I would just attempt to flip it... Do you know any of the specs?
Old 03-30-2013, 08:30 PM
No, how can I find specs? I found some side play is ok just need to measure and see if its in specs. I was told it was 76mm and it has about a 5 inch inlet and outlet
Old 03-31-2013, 12:09 PM
Can I unbolt the housing covers and mic the impellers? I don't wanna mess it up to where it would have to be rebuilt.
Old 03-31-2013, 01:47 PM
Have 1.23 on exhast housing with 5 in OD with 11 fins
Cold side is .81 with 7 fins also 5 inch OD
Exhaust inlet is rectangle and is open inside (no seperator) measures 5 OD and about 3.5 ID across
Old 03-31-2013, 04:37 PM
HexenLord's Avatar
The TV8513 is an 88mm turbo, not a 76mm.
Was OEM on a 8v 12.6L diesel.
Its a very large turbocharger. Probably not suited for a 5.3. Most guys use them on big blocks when pushing for 1000+ HP.
Old 03-31-2013, 05:52 PM
Dam, so what will it do with 5.3? Lag issues or to much back pressure. The guy was gonna use it on a big block. Was it a good pick for 140?
Old 03-31-2013, 07:24 PM
smokin91rs's Avatar
Default s
it will probably have some lag on a 5.3 with the exhuast wheel being so big. if you decide to get rid of it let me know. i have a tv7511 71mm 1.08ar exhaust on a ly6. and would like to swap that 88mm wheel and comprssor cover onto mine.
Old 03-31-2013, 10:09 PM
I guess I'm gonna run it and see what happens. What size injectors, waste gate and blow off valve would yal recommend?
Can I buy injectors that will work with truck intake that will also transfer to a victor jr down the road?
Quick Reply: boosted newb
