turbo 6liter woes
Old 04-07-2013, 07:35 PM
JaYZeig's Avatar
Default turbo 6liter woes
been having a problem I have been fighting for a sometime now, my 99 trans am, iron lq4, turbo...will occasionally close the sparkplug gap on cyl 7, and it happened once on cyl 2. im running ngkbr7-ef plugs
ONCE it chipped a ring land right of cyl 7, and it smoked out the valvecover breather and you can tell the engine was hurt, as it would also misfire at idle only. so I removed/replaced cyl 7 piston and rings and all was good.. well this happened again today, I got on it hard, rowing through gears, full boost, brand new plugs and wires, and cyl 7 closes the gap again and I had to dogleg it home. im gonna run a borescope down the sparkplug hole and check out the piston, but I am doubting its hurt, as I have no driveability issues after I replace the plug.
car was tuned properly, just trying to get an idea of what could be going wrong here, possibly a weak coilpack? or a bad map sensor (3bar sd tune) and its detonating closing the plug gap? HELP!
Old 04-07-2013, 07:45 PM
9 Second Truck Club
stock48's Avatar
Need to do a compression check. What fuel were you running?
Old 04-07-2013, 07:47 PM
JaYZeig's Avatar
right now im running 93octane..no meth, just straight pump gas
Old 04-08-2013, 12:13 AM
LilJohn's Avatar
93 octane... no meth...and a 7 heat range plug.... and youre honestly wondering why yer nippin plugs and hurting holes???
Old 04-08-2013, 07:22 AM
Old Geezer's Avatar
I'm w/ Lil on this one ^^^^^^
Just what is "full boost"??????
Old 04-08-2013, 07:31 AM
JaYZeig's Avatar
13pounds is full boost for me...
im thinking its gonna need meth for cooling because its detonating
or switching to e85.
Old 04-08-2013, 07:36 AM
9 Second Truck Club
stock48's Avatar
Yea the 91-93 oct is hard on **** especially with no tq converter to soak up load.
Old 04-08-2013, 07:55 AM
1sick-Z's Avatar
What is wrong with the plugs he is using? I have a set or BR7EFs in my toolbox but I run a TR6 and it worked fine for me at the same boost level so I just left them. I wondered about the BR7s
Old 04-08-2013, 08:14 AM
Sarg's Avatar
Probably a tad hot on straight 93.
Old 04-08-2013, 08:28 AM
1sick-Z's Avatar
Not to jack but how how would you say the TR6s are for that boost? This is making me want to go to 8s even though there were no problems yet.
Quick Reply: turbo 6liter woes
