holley 12-1800 fuel pumps for FI
Old 09-14-2014, 10:40 PM
  #41
dmracing's Avatar
Old 09-14-2014, 10:41 PM
  #42
dmracing's Avatar
not my pic
Old 09-15-2014, 06:56 AM
  #43
6togo's Avatar
How old was the pump that failed?
Old 09-27-2014, 05:40 PM
  #44
Bondobird's Avatar
Bump...anyone else have problems and or great success with these pumps? I'm really looking into them myself
Old 09-28-2014, 12:30 AM
  #45
ls1curt's Avatar
Only a couple months. Holley did make it right though.
Old 09-28-2014, 07:44 AM
  #46
6togo's Avatar
Did both pumps fail or just one in the unit allowing the car to still run?
Old 09-28-2014, 10:23 AM
  #47
ls1curt's Avatar
just one
Old 09-28-2014, 12:02 PM
  #48
baggins's Avatar
Anyone used this twin outlet deal on their pump? Looks like a good idea
http://www.aftermarketindustries.com...or-plate-p187/
Old 01-02-2015, 09:30 PM
  #49
murph91's Avatar
Has anyone used this pump in tank?
Old 01-02-2015, 11:23 PM
  #50
LSmonster's Avatar
Beware, Holley now says that the 12-800 pump is a "RACE" pump only! The "new" 12-800-2 is now the new "street" pump... What a bunch of BS!
Old 01-03-2015, 05:29 AM
  #51
stevieturbo's Avatar
Given the pump is basically just 2 in-tank pumps mounted in an enclosure so you can use them externally, it should be fine to run in-tank.
Old 01-03-2015, 06:10 AM
  #52
forcd ind's Avatar
Default pump
A lot of cont. over these pumps now, Holley is sup. doing a redesign due to "hot fuel issues"
Old 01-03-2015, 09:53 AM
  #53
When you take a pump that's designed to be surrounded by cool fuel and place it in a small enclosure, it is less then ideal.
Although it would still be getting a flow of fresh fuel around it...it just must not be good enough
Perhaps they need a slightly larger casing for them or something
Old 04-17-2015, 07:06 AM
  #54
HeavyMetl's Avatar
I've put a couple hundred miles on my 12-1800 with E85 and so far no issues. It's important to mount the pump 'flat", as mounting it on the side of a frame rail results in the high side beind dry and causing failures. It is nice and quiet and so far I'm impressed. But, as always, needs to pass the test of time.
Old 04-17-2015, 08:36 AM
  #55
Moderator
denmah's Avatar
i have a 12-1800 on my fairmont right now
billet 76 just went on and i trashed my converter and trans
hopefully i get some nice high hp numbers
Old 04-17-2015, 08:38 AM
  #56
Moderator
denmah's Avatar
i have the second part of the pump turning on at 8psi with my ms3gold ecu
so far fuel temps are fine also, also with mixed ethanol content fuel im doing good, currently at 60%~
Old 04-17-2015, 08:39 AM
  #57
Moderator
denmah's Avatar
i did 740whp on gasoline so far
engine
turbo
trans
and converter failure have been holding me bcak
Old 04-17-2015, 11:53 AM
  #58
ablakez28's Avatar
I made 888rwhp and went 150 on the hp-1400 pump. It isn't mounted flat either with about 4k miles.
I am switching to the 1800 and will try to flat mount it. Looking to be around 1100rwhp on C12 this year.
Old 04-17-2015, 01:57 PM
  #59
RonSSNova's Avatar
I have the 1800. 1 year of race street use. Although it's far from a daily driver.
It's not mounted flat either. The instructions said nothing about that.
Both pumps run full time.
I don't race in the heat. I don't enjoy that at all.
I'll change to the magnafuel if this one fails. On E85 so I need more pump anyway
Old 04-17-2015, 08:36 PM
  #60
HeavyMetl's Avatar
When I went to Holley for EFI training class they mentioned the flat mounting. Don't know if they'll change the instructions, but they admitted that was certainly a cause of failures they'd seen.
Quick Reply: holley 12-1800 fuel pumps for FI
