Bracing a heavy T6 turbo without solid motor mounts?
Anyone have pictures of how they braced there beast of a T6 turbo? I don't have solid mounts so I can't brace it to the frame rails which is all i could find. Should I build something elaborate coming from the head? I've built a small T4 turbo brace before using the head but I'm not sure it would have supported so much weight.
Mine will be on the passenger side of an lm7. Thanks in advance!
You can still brace it to the frame rail if you use flex joints I've done it on a few cars. Next best thing is coming off the head. I don't have any pics of that car. But I'm sure somebody has some pics to post up for ya.
Ill get the pics, but I ran mine off the frame, 2 threaded rods, with springs on the rods so it can move, cause I couldnt use flex pipe on pass side its to close to manifold.
^ looks alot like my setup, same body style truck even. I actually breaced mine to the fender and tot he frame. no solid mounts. daily driven for about a week and no issues so far. about to change the setup though
