Water cooled comp turbo.
Old 04-29-2013, 05:09 PM
Mereniuk's Avatar
Default Water cooled comp turbo.
Ok, first I know this topic has been beaten to death.
And I know the best way to get water to the turbo is the big plug on the driver's side head, and use a T in the heater core lin, for the return. But, since I'm in a crunch for time, and my Dyno time is booked. What's a simpler way to get water to this front mount setup? This issue is I can't get that fitting I need for the driver's side in time. So my questions are..
1- if a person was to run a tee into both heater core hoses, how will this work? I always thought coolent doesn't flow to the heater core unless you turn the heat on in the cab?
2- there's the steam vent hose from the front drivers side head, into the fitting on the radiator, would this work? Or not enough flow or pressure? Cause that would be simple.
Sorry for these questions, but the search just isn't helping.
Thanks in advance!
Old 04-29-2013, 06:05 PM
SPRAYED 01's Avatar
i had my comp turbo hooked up from that steam tube hose to turbo,from turbo to a barb i welded into my radiator right by the cap. 5k miles and no issues. if you have a stock radiator you could probably do the return to the over flow hose
Old 04-29-2013, 06:35 PM
Mereniuk's Avatar
My rad is the Griffen rad everyone uses, stood up vertical, and I welded a barbed fitting on it for the steam vent. I will do it this way! Thanks!
Old 04-29-2013, 06:43 PM
SPRAYED 01's Avatar
You are good to then, same exact way i had it. Honestly you could probably just leave it that way for ever. What comp turbo did you go with and what size engine?
Old 04-29-2013, 06:50 PM
Mereniuk's Avatar
CT43 7879, and for now it's the stock bottom end. Until next year! Then going for a iron block 408 I think.. I'm sure my mind will change again before winter haha
Old 04-29-2013, 07:11 PM
SPRAYED 01's Avatar
Post up results if you can,good luck.
Quick Reply: Water cooled comp turbo.
