HURON SPEED A/C TURBO KIT. Spring special
Old 04-30-2013, 06:55 PM
LS1Tech Sponsor
Huron Speed's Avatar
Default HURON SPEED A/C TURBO KIT. Spring special
With spring in full swing here in MI, I figure some of you guys around the country (and especially locally) would be extra motivated to make some boost and get out there and cruise. with the air conditioning on of course!
So here is what i decided to do. we are offering a few different special prices on these A/C turbo kits. we want to get some more of these out there and have people get them on the cars. we love to see the build thread and videos pop up on youtube!
If you are interested, please PM me and i will let you in on the deal. these should be ready to ship out in a few weeks.
If you have any questions about this kit, or ANY other product or service Huron Speed provides. please do not hesitate to PM me. I'd love to help.
***Kit has many of the same features as the already successful Truck Manifold kit, however obviously retaining A/C with the use of a C6 manifold and a truck manifold combination fitting through a Turbo K-member. Kit will require the use of a Turbo K-member (was built around a PA Racing Super Turbo K-member) This can be purchased with your kit for a great price, or separately.
Includes:
-2-piece hotside in 2.5” piping w/ T4 flange and 44mm Wastegate Flange
-2.5” V-band clamp for easy connection of 2 hotside pipes.
-3” 1-piece Downpipe
-3" Cold side piping from turbo to FMIC to Throttle Body
-MAF Delete pipe
-50mm Blow-Off Valve Flange on Cold side piping
-4" core front mount Intercooler
-All exact, specific couplers
-Extra exact couplers to run or not run the MAF Delete
-All exact, specific T-Bolt clamps
-F-body front mount intercoolers brackets
-F-body alternator & tensioner relocation brackets
-Hardware to mount Turbo, intercooler brackets, intercooler, alternator & tensioner relocation to vehicle
All piping made from 321 stainless steel, fully polished.
Advantage of using factory GM manifolds, no fear of aftermarket headers or manifolds cracking due to the turbo weight!
Advantage of having the Huron Speed customer service!
Requires Turbo, Wastegate, BOV, Oil Lines, Pusher Fans, Misc Hardware, passenger side Truck Manifold to use on drivers side, and a passenger side C6 Manifold to run on the passenger side to complete
Kit requires a Turbo K-member (built around the PA Racing Super Turbo K-member) and lowering or removal of front sway bar.
***Already have a Huron Speed Single Turbo Truck Manifold kit and are interested in this A/C retaining kit? No worries, we have your covered! Also available will be our A/C Retaining Upgrade kit for all Truck Manifold kit owners! Included will be the following:
-Instructions on how to shorten one cold side pipe
This upgrade kit will convert your Truck Manifold kit over to our A/C Retaining kit so you can get the A/C back on your vehicle! We will also allow an exchange program to help keep your costs down as well!
Price for the upgrade kit (Available ONLY to customers who purchased a Truck Manifold kit through Huron Speed)
-$1199 outright
-$899 with exchange of your used Truck Manifold Crossover Pipe and Downpipe
-$599 with exchange of your NEW Truck Manifold Crossover Pipe and Downpipe
If interested in this A/C upgrade kit, send me a PM for more information!!!!
Huron Speed
__________________
YOUR SOURCE FOR ALL THINGS TURBO!
CASEY@HURONSPEED.COM
Check us out on Facebook at: www.facebook.com/HuronSpeed
TWITTER @HURONSPEED
Old 05-01-2013, 08:54 PM
LS1Tech Sponsor
up top!!
__________________
TWITTER @HURONSPEED
Old 05-01-2013, 09:00 PM
yelo04goat's Avatar
GTO single kit!!!!!!
only need hot side please
Old 05-01-2013, 09:14 PM
agressive's Avatar
Will a pt88 fit with this kit?
Old 05-02-2013, 12:46 AM
deiselfever1's Avatar
i have talked with you some, this kit is just what i was looking for. id like a price for the hotside pipe. the k member. and the whole kit if possible.
Old 05-02-2013, 11:15 AM
LS1Tech Sponsor
we'd be more than happy to build a gto kit. but we need a gto to do it on!
we havent tried it with the ac kit. physical size should not be a problem, however you would have to fabricate your own downpipe, and maybe make a few other changes as this kit was not designed around something with those specs. but will it bolt on? yes.
i can certainly do that for you. expect a pm soon!
__________________
TWITTER @HURONSPEED
LS1Tech Sponsor
and to everyone else who has pmed and emailed me, they have all been returned THANK YOU for the huge response on this.
__________________
TWITTER @HURONSPEED
Old 05-02-2013, 01:49 PM
venom ws7's Avatar
Bump for a great kit/price and for HS Crew I wish I was close I would send my ZO6 to you to build some nasty TT kit
Old 05-02-2013, 01:54 PM
LS1Tech Sponsor
thanks man! i wish you were closer too! id love to do a kit on your Z!
get some shipping quotes...cant be THAT expensive..
-Casey
__________________
TWITTER @HURONSPEED
Old 05-02-2013, 02:12 PM
venom ws7's Avatar
Casey from all the way overseas to U.S believe me it can be that expensive
Old 05-02-2013, 03:59 PM
agressive's Avatar
So whats the biggest turbo u can fit on this kit?
Old 05-02-2013, 10:51 PM
SPRAYED 01's Avatar
Is that the shop car with that kit? What pusher fans do you guys run? Has this kit been tested to not over heat with ac on idling?
Old 05-02-2013, 11:00 PM
SPRAYED 01's Avatar
Oh and that's the cleanest engine bay ever
Old 05-03-2013, 10:46 AM
LS1Tech Sponsor
turbonetics 7875, precision 7675, comp 7879 are the biggest ones that will be direct bolt on
that is a customer car with the kit, its just starting to be nice weather here in MI. we are confident there will be no cooling problems
-Casey
__________________
TWITTER @HURONSPEED
Old 05-03-2013, 10:47 AM
LS1Tech Sponsor
yes the car is SUPER clean
__________________
TWITTER @HURONSPEED
Old 05-03-2013, 01:06 PM
SPRAYED 01's Avatar
What fans are they?
Old 05-03-2013, 02:01 PM
LS1Tech Sponsor
What fans are they?
a pair of derale 16925's
__________________
TWITTER @HURONSPEED
Old 05-04-2013, 09:01 PM
LS1Tech Sponsor
Superman09's Avatar
__________________
Featuring 6 different turbo kits for your F-body!
Old 05-07-2013, 11:33 AM
LS1Tech Sponsor
tuesday bump! summer is officially here. who needs boost! shoot me a pm
-Casey
__________________
TWITTER @HURONSPEED
Old 05-09-2013, 11:51 AM
LS1Tech Sponsor
up top! pm me for a sweet deal!
__________________
TWITTER @HURONSPEED
Quick Reply: HURON SPEED A/C TURBO KIT. Spring special
