4" Cutout Availability, might have to go 3.5"
does anyone know where to get an inexpensive 4" cutout
found a bunch of 3.5" but the only 4" that I have found is a Quick Time stainless that is stupid expensive. not looking for stainless and not looking at that pricing point
trying to put a 4" after the downpipe before it necks into a 3" catback, but looks like it might be a 3.5"
Here is the one I am going to buy for my setup. http://compare.ebay.com/like/390571395820?var=lv<yp=AllFixedPriceItemTypes&var=sbar
It's 4" and only $88 from EBay and its a manual one so Ill just run my down pipe off the 4" side and shrink it down to 3.5" for cruising. Then at the track just open the cutout.
Here is the one I am going to buy for my setup. QTP Exhaust Cutout Manual Stainless Steel Polished Clamp-On 4" Diameter Each on eBay!
4.0 inch Custom Y-adapter
or the stainless version for $50
4.0 inch Stainless Y-adapter
The qtp y pipe for cutout is only around $45 and its ss. . I went with a 4" from Jegs or summit I cannot remember but it was alumnized steel and only around $30. I had to spend a lot of time modifying it because there was a lot of pipe overhang where they welded it together. Not fun at all. I went with the DMh electric cutout but took it off because it started leaking and rattling real bad.
http://www.badlanzhpe.com.webshop3.a...e0d1f1d3af263e
You guys with the Badlanz stuff...keep them far enough away from the turbo...I fried my 4" electric cutout a couple years ago from excessive heat. Granted it was only like 12-16" off the turbine outlet due to packaging constraints
