I need help running my vacuum Lines I'm in over my head here
I paid someone todo a complete turbo set up from start to finish and dude burned me.
So here is what I came up with so far.
Car is a LX foxbodys mustang. Was a 5 spd car I converted to auto
Has a 2005 5.3'with DBW set up on a ls1 intake manifold w/ rails and injectors
Trans is a 4l60e with transgo HD2 shift kit
What I need help with currently is running my vacuum lines.
I have a on 3 performance 76mm .80 AR turbo
XS Power 44mm wastegate
RMS (I believe, it's a blow off I bought through calspeed about a year back and never used on another build) so it's like brand new and currently my only blow off
I have a turbosmart manual boost controller w/ the adjustable **** on top
I have a snow methanol Injection stage 1 kit
Also have a Godspeed black aluminum vacuum manifold with 6 ports off it
I'm running a ultralite 2 wide band and ultralite boost/vacuum gauge
Can someone draw me up a little ms paint or something similar to follow to run everything? Thank you
Can I reference everything off the vacuum manifold? I put a half inch T in the middle of the vacuum line from the back of the intake manifold to the booster.
I just don't know where to run which scum line from my waste gate as it has 2 vacuum ports and where do I run a vacuum line to my diaphragm that controls
S my methanol injection pump?
If you look, Tial has diagrams online for their 44mm wastegate. Personally I have had good luck just leaving the top port open to atmosphere and taking a line to the side port. I am not sure what you are asking about the snow kit, but it is boost referenced, so just run a line from the block to it.
