LS9 head gaskets..... why....
Old 05-14-2013, 02:00 PM
NasbaGoat's Avatar
Default LS9 head gaskets..... why....
Backround....
2004 GTO/243's/LFPE GT9 cam/MP112HH/10.75lbs boost
Pushing water into the oil, heads are at the machine shop to be checked for cracks and straightness....
Question....
In my reading i have determined that the LS9 head gasket is 4.1" bore 7 layer MLS gasket and the LS1/6 is a 3.91" 5 layer MLS gasket. I have also gathered that people think more layers/ purpose build gasket is better and that people have used them successfully.
What i havent found is an explanation as to why it is ok to use a gasket that has a much bigger bore than the cylinder and why it wont create problems for me.
Old 05-14-2013, 02:03 PM
Ferocity02's Avatar
Myself and many others have been using them on their 5.3 and 4.8 blocks which have an even smaller bore.
Old 05-14-2013, 03:18 PM
LS1Tech Sponsor
Slowhawk's Avatar
People use them, I see no reason too.
Our builds always get the correct bore size and the high hp cars get copper sprayed. No gasket problems- ever.
Old 05-14-2013, 03:24 PM
Twin turbo c5's Avatar
Why? Because they work. They have proven there self again and again By me and many others. Use em.
Old 05-14-2013, 06:24 PM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
If you are running the proper bore size and your heads have the proper sized combustion chamber I will recommend the LS9 head gaskets for bang for the buck. If you want cheap head gaskets for a 5.3 use the GM MLS LS1 gasket set. It's cheaper than a pair of LS9 gaskets and they are sized properly for the application.
Do people use LS9 gaskets successfully on small bore setups? Sure they do. Does successful misuse of a part make it proper to continue to do so? No. I do not recommend an LS9 head gasket for use on a small bore like the 5.3 and I recommend that anyone installing heads does so with the properly sized head gasket for their combination.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 05-14-2013, 08:13 PM
trav-tech's Avatar
well put scoggin dickey. im running and have been running the standard 3 layer ls1 gaskets on my 5.3L making and holding 876rwhp and dont see the point in paying more for a gasket with the incorrect bore size when the normal gasket holds the pressure just fine. most guys will bend the stock gen 3 rods long before pushing water even with stock stretch bolts.
Old 05-14-2013, 11:18 PM
a-low's Avatar
I always wondered the same thing, large bore gasket on a small bore
with more layers just drops compression. But what the hell do i know.
Old 05-15-2013, 06:43 AM
stevieturbo's Avatar
More layers has nothing to do with compression. Overall thickness is the same.
But any of the GM MLS gaskets work superbly, I'd always prefer to use the correct bore'd gasket for my engine unless there was no alternative.
Old 05-15-2013, 07:50 AM
68 SS's Avatar
The most important thing is the surface finish on the heads and block without that being right you will have issues.
Old 05-15-2013, 06:09 PM
9 Second Truck Club
stock48's Avatar
The extra layers allow the Ls9 gasket to hold seal when heads flex.
Old 05-15-2013, 07:58 PM
LS1NOVA's Avatar
$35 a pair LS1 MLS gaskets working well on my small bore. I agree with the others, I just dont like the gap.
Old 05-15-2013, 09:51 PM
Wicked69's Avatar
LS9 head gaskets, just wipe the surface and have hit 25lbs of boost without pushing water. Short bursts. Recently 11.0 compression, 14lbs of boost, head gasket didn't go but ring land let go.
Old 05-15-2013, 10:54 PM
9 Second Truck Club
stock48's Avatar
I have pushed water past 20psi with the std 3 layer truck gaskets. Been up to 25 psi with ls9's S480, 6.0L with 317's and no water pushed. Combo went 6.03/117mph on 22 psi @ 4800lbs so it's pushing things a little lol .
Old 05-16-2013, 09:39 AM
TDMKR496's Avatar
Do you have a build thread for your truck??
Old 05-16-2013, 01:29 PM
badhombre's Avatar
I just had this same conversation with a friend. I ordered a set of LS1 MLS gaskets through Jegs. he told me I should return them and buy the ls9's. I have seen the ls1 gaskets holding up to plenty of abuse so far, so I think I will be good. especially in combination with studs
The following users liked this post:
Eat.sleep.slide (02-22-2023)
Old 05-16-2013, 04:35 PM
9 Second Truck Club
stock48's Avatar
No build thread I built truck back in 2006. Built the whole thing in a week and have made little upgrades, and down grades here and there. Not really much to it other than the turbo kit, engine swap, and upgraded transmission. Every thing else is stock 2003 truck down to the factory intake, tb, etc lol. There are some older vids on youtube under stock48.
Old 05-16-2013, 04:36 PM
Chicago TDP's Avatar
Doesnt it all boil down to the fact that the GM LS9 is a FACTORY supercharged engine, making almost 650 HP out of the box?
The fact that a OEM made a gasket that will hold up to boost on a factory motor might indicate that it is the "premium" choice to hold boost.
I see it as if GM engineered/built a gasket for a high HP boosted motors (so they dont loose their *** on warranty claims), then I will bolt a set under every boosted motor I put together.
Old 05-16-2013, 05:29 PM
They also built said gasket for a 4.065 bore engine. There is a reason head gaskets are offered in varying bores. The fact that they engineered something to work properly on an LS9 doesn't mean it's the best for a 5.3 just because the 5.3 is now boosted. There are still big differences between the two engines.
An LS9 head gasket on a 5.3 leaves you with a .051" gap between the block and the head that is .095" wide all the way around the bore (compared to a properly sized 3.910 bore gasket). This is simply not ideal regardless of whether it works or not.
The GM 3.910 bore MLS gaskets are good for decent boost and power. When exceeding what they are good for it's best to step up to a properly sized Cometic.
__________________
Xaviarrahl (11-29-2023)
Old 05-16-2013, 06:33 PM
1BADAZZSS's Avatar
I know MaxMitchell and skinnies have been running the ls9 gaskets on small bore motors (l33s) and have no issues. I lifted a head last year on a jy 6l with mls gaskets. Changed to the ls9s and no issues since!
Old 05-17-2013, 06:35 AM
MonmouthCtyLS7's Avatar
I hear both ends but theres a reason tons of guys run 9's on boosted motors...believe the thickness effect out weighs the bore differences.
Quick Reply: LS9 head gaskets..... why....
