Set me straight on pump gas
Old 05-14-2013, 05:10 PM
bikerman9967's Avatar
Default Set me straight on pump gas
Can someone clear this up for me. What is the most reliable amount of hp you can get under boost with pump gas on the ls platform. Say no meth but with air to air inter cooler . All premium internals and best flowing heads . I've heard too many different numbers and I want to know what's true and what's bull.
Old 05-14-2013, 05:12 PM
stevieturbo's Avatar
There is no generic answer and it will depend on many variables. It's far too vague a question because very few people actually try and build a high power pump fuel only car here.
Old 05-14-2013, 05:40 PM
There's nobody here driving a high hp street car?
Old 05-14-2013, 07:03 PM
SPRAYED 01's Avatar
I do. I use 93 up to 650whp on the street. But i don't feel really good about it. I don't stay in in for more than 5 secs blasts on the High way. I have blown up 2 forged Motors at the track trying to be cool and using pump gas. Never again, i use race gas at the track now. Im planning on getting a meth kit for more safety on the street. Put it this way, don't go 0 to 150 on 93 with anything over 12psi and expect it to last forever. You will get a bad tank of fuel one day
Old 05-14-2013, 07:04 PM
5.slow99's Avatar
There's a couple guys a I know making mid 600ish but again what's your definition of high horsepower and what setup are you running?
Old 05-14-2013, 07:39 PM
buick_lsx's Avatar
915 rwhp on a Dyno jet here, pump 93....it can be done
Old 05-14-2013, 07:57 PM
SSZ
SSZ's Avatar
Where did you get that 93 from if you dont mind me asking? My friend works for a large oil company. He has told me on more than one occasion that the higher octane fuels really arent much more cost for the gas company. THey make large profit margin on higher octanes.
Old 05-14-2013, 08:17 PM
I'm looking at building a 1000hp street chevelle. I would like it to run on pump gas, but if it can't be done, it can't be done. I can get e85 but its from the pump as well and not sure it's trustworthy
Old 05-14-2013, 08:28 PM
SSZ
SSZ's Avatar
ANd on the flip side there are tons of guys making great power on E85. I wish it was close to me.
Old 05-14-2013, 08:32 PM
SPRAYED 01's Avatar
You can have a car that cruises around on 92 no problem. is your question racing down a 1/4 miles track with 1000hp And only 93 octane? Buicklsx, did you just dyno on 93 or do you make full passes at that level on 93?
Old 05-14-2013, 08:43 PM
buick_lsx's Avatar
Full passes, track and highway...it has been 110 and 137 so far at the track...and those numbers are with a locked converter btw.
Those passes were with with about 730 hp though...hope to get to the track next weekend to finally get in the 9's if the new converter doesn't hurt me to bad
Old 05-14-2013, 08:44 PM
lbm13186's Avatar
GO METH, extra 6-800 is worth the piece of mind, making over 600 on pump w/ meth and dont worry about jumpin on it at any time
Old 05-14-2013, 08:47 PM
buick_lsx's Avatar
And of course if I had e85 I'd be all over it, def safer but this has worked for 4 + years now...2 years over 600rw, last year at 730, and around 900 since lsfest last year
Old 05-14-2013, 08:48 PM
WSsick's Avatar
This is a car local to me. Pump gas and meth, 16 psi.
1,124 rwhp
From the video description (he also has a thread on here):
Lsx block 427 CI, 4" dragonslayer crank, oliver billet rods, JE custom pistons, WCCH All-Pro heads, Injector Dynamics ID 1000 injectors, Aeromotive Eliminator pump, custom -10 feed, -8 return fuel system, Alky control Meth injection system, stock LS7 intake and 90mm throttle body, IPS twin turbo kit with custom headers, RPS Triple disc clutch and 100% stock driveline. Tuned By Dave Steck at DSX Tuning.
Old 05-14-2013, 08:49 PM
SSZ
SSZ's Avatar
Sprayed. I am from southern ontario. I asked about the 93 cause in climates where we live the additives used for the different seasons causes inconsistencies in the quality of the fuel itself. At least that is what i am told. So where do you live Buick and would you mind listing your choice of gas station.
Old 05-14-2013, 08:52 PM
buick_lsx's Avatar
I live in tennessee and I normally stop at a shell, don't really care though, Hollingsworth oil supply's gas to almost all of the stations in my city and the next closest, so it's all the same gas...
Old 05-14-2013, 09:05 PM
SPRAYED 01's Avatar
What kind of timing and size of turbo? Buick
Old 05-14-2013, 09:11 PM
code4's Avatar
more cubic inches the better, it's simple physics.
Old 05-14-2013, 09:17 PM
HydroStream6's Avatar
E85 is hands down your best bet, period. Do it!
There's cars trapping in the 160s on E85, probably faster.
Old 05-14-2013, 09:21 PM
buick_lsx's Avatar
19 degrees of timing normally, if iats go above 120 it backs off to 15 degrees
17 psi and a .032 jet
Standard cast wheel, small 83exh wheel s475
Quick Reply: Set me straight on pump gas
