How to test if BOV opens premature
Old 05-17-2013, 04:49 PM
yttz's Avatar
Default How to test if BOV opens premature
Whats the best way to tell if you BOV is opening premature and leaking boost?
Old 05-17-2013, 05:15 PM
stevieturbo's Avatar
A little odd...but I guess you could run a long hose to it's outlet and listen while you drive. That would at least give you a pretty certain indication that it is staying closed when on boost.
You could do all the static tests in the world, but at least the above is a real world scenario.
Old 05-17-2013, 05:16 PM
buick_lsx's Avatar
If it opens even just a little bit you would be lucky to make a couple lbs
Quick Reply: How to test if BOV opens premature
