Need help!!!!What injector fuel pumps etc for E85 set up
Well it's about that's time to buy my fuel system in my build.i need help on what type of fuel system should I run on my build.i wanna run E85 so what pumps injectors etc should I run on my set up.i have a 2002 camaro with a forged 383 with a 4l80e, ford 9", gt4788.im aiming to hit 1000rwhp.i would appreciate any help guys.thanks for the help.
Not knowing if you want to keep your gas tank in tact with internal pumps or not, it's hard to say. I went with the Fuelab pump (external) and their electronic regulator, but this was on a complete swap, and not a daily driver. For a dual purpose car, the dual pump setups internal are nice, but a little more complicated to get setup. I also like running a bigger fuel line so I went with 5/8" although its overkill, I'll never have a problem with volume as long as the pump can keep up pressure-wise.
Give Lonnie's a ring to discuss your needs, they were extremely helpful when I went through this.
LS1Tech Sponsor
We are using a Magnafueler pump with a set of FIC 2000's. Car drives great and we are logging fuel pressure going down the track. No drop. Actually climbing with the boost referenced regulator.
__________________
See what's in our shop on Facebook! Customer Build Blogs!
www.pcmofnc.com
Performance Installs - Dyno Tuning - Custom Camshafts & Valvetrain - Remote HPtuners Tuning - Mail Order Tuning & Sales
704-307-4227
www.pcmofnc.com
704-307-4227
