procharger still spinning after ignition is off?
Old 05-27-2013, 05:04 PM
baycityrides's Avatar
Default procharger still spinning after ignition is off?
my F1A still spins for a second after i cut the ignition... it seems new to me but i just caped the cutouts so its a whole new sound... i confirmed it was the blower spinning today, i had a buddy start the car and shut it off and sure as **** it was the supercharger still rotating... i thought i broke something so i pulled the belt off of it and grabbed the pulley and grabbed the impeller and they are still connected... what could be causing it?
Old 05-27-2013, 05:13 PM
haulass350's Avatar
thats odd, i wouldnt think it would spin since its belt driven, as soon as the engine stops turning so should the blower.
Old 05-27-2013, 05:34 PM
stevieturbo's Avatar
Are you using one of those clutched pulleys ?
If it's a normal pulley, it should be impossible for it to spin with the engine off as there is a direct mechanical linkage stopping it.
Old 05-27-2013, 07:23 PM
11SECSS's Avatar
Unless the pulley was put on without the key way.
Old 05-27-2013, 07:54 PM
key is there in the pulley, it has me baffled!
Old 05-27-2013, 08:22 PM
Blackbirdws6's Avatar
Maybe a large lack of belt tension? Engine turns off and the momentum of the blower overcomes the available grip of the belt just for a second. Just spitballing here.
Old 05-27-2013, 09:40 PM
silver_82's Avatar
theres a large set up ratio gearset in the procharger. you sure your eyes aren't playing tricks on you as the motor is winding down
Old 05-27-2013, 10:06 PM
that may be it... they are new belts... but ill just have to try it later... every time i fix something, another thing breaks!!
Old 05-28-2013, 10:20 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
Is the belt still turning?
Definitely post a video so we can see what you're seeing.
Old 06-01-2013, 09:18 PM
heres a video of it... its still moving air, the sound is normal, just it keeps spinning...
Old 06-01-2013, 09:27 PM
Tally TransAm's Avatar
wait its an lt1?
has to be an issue with the opti. . .
sorry man, i had too. weird though
Old 06-01-2013, 09:30 PM
11SECSS's Avatar
I would pull the pulley off to see if the keyway broke would be my geuss.Unless something has broken internally.
Old 06-01-2013, 09:37 PM
key is still in it, but if one of the gears or shaft broke wouldnt it not move air anymore? and wouldnt it be all bound up? thing feels like it did brand new... it just keeps spinning LOL its making me nervous!
should add there is maybe 500 miles on this unit... i had it rebuilt after the cone fell off and sucked its self into the impeller... procharger fixed it for free... as you can hear in the vid it sounds perfectly normal, even the "spin down" sounds like it would if you just spun it with your finger real fast.
Old 06-01-2013, 10:40 PM
haulass350's Avatar
you can always take and crack the case apart and see if there is anything visually wrong with it. i dont know if i would be running it with it like that haha.
Old 06-01-2013, 11:00 PM
i now have the belts off of it. i had them on just to take this video.
Old 06-02-2013, 03:19 AM
it's a poor video. Can you show us the actual impeller wheel throughout this test ?
And again, what upper pulley are you using ? Is it one of their clutched/sprag pulleys ?
Old 06-02-2013, 07:48 AM
UNDER PRESSURE MOD
I wasn't able to tell in the video, but is the belt to the blower still turning once the motor shuts off?
Old 06-02-2013, 09:19 AM
the belt is stopped., i honestly dont know if the impeller is. there isnt much clearance between the header and the inlet. ill put a belt on and try and squeeze a camera in there... but i thought the sound of it was the important part
Old 06-02-2013, 10:46 AM
11SECSS's Avatar
Have a buddy start the car while you hold camera but to me sounds like impellere is still spinning or poss a bearing inside is turning ?
Old 06-02-2013, 10:54 AM
thats what i was thinking is one of the "double bearings" they use i guess is still spinning... but its a crap shoot lol
Quick Reply: procharger still spinning after ignition is off?
