Oil feed for passenger mount turbo?
I was thinking that the factory lq4 holes above the oil filter is quite a bit away from my battery tray area where the turbo will sit since it's in the back of the drivers side. Suggestions?
Yeah it runs under the oil pan right along the k member. It doesn't get in the way and I have full AC. Return line is to the passenger side of the oil pan maybe 1/3 of the way towards the rear.
The length of the feed line doesn't really matter. Mine's probably around 6' of -3an. The pressure in the line will be the same pressure as the engine. Or if you want to be technical, the pressure would be marginally less due to the friction of the fluid inside the line.
I tapped mine from a t fitting at the back of the block where the oil pressure sender threads in. Just under 3' of line and was very easy to route. Keeps it all on the top side and away from belts, etc
