SALT 370ci with a single 88mm turbo - Engine dyno VIDEO!
370 cubic-inch LQ9 iron block
Lunati 3.622-inch crankshaft
Lunati Pro-Series 6.125-inch rods
Diamond anodized 4.030-inch piston
10.2:1 compression
Total Engine Airflow / Trick Flow Specialties 235cc heads (4-bolt)
T&D Rockers
Steve Petty / Pro Line 256/262, .759/.759, 116 solid roller camshaft
Edelbrock Pro-Flo XT intake manifold
LS9 head gaskets
1/2-inch ARP head studs
Turbonetics Y2K 88mm turbo, .96 back
Turbonetics air-to-water intercooler
Vibrant Performance tubing, piping, and VanJen clamps
Any questions, ask away! The final numbers will be in an upcoming issue of GM High-Tech Performance but we can say that they might look something like this; X,XXX / X,XXX on XX-psi
What type of rockers, valve springs, retainers, and locks used . Was there any fabr
http://youtu.be/dgs-HdEdwRQ
10.2:1 compression
T&D Rockers
LS9 head gaskets
10.2:1 compression
T&D Rockers
LS9 head gaskets
What type of rockers, valve springs, retainers, and locks used . Was there any Fabrication
Only 10 yrs late there, Peri00.
The following 3 users liked this post by Old Buzzard:
