Smallest T4 Turbos for LS2 Twin Build
Old 06-16-2013, 07:52 AM
flsupraguy's Avatar
Default Smallest T4 Turbos for LS2 Twin Build
I'm fabbing a custom twin system for my stock LS2 and wanted your opinion for the smallest twins you recommend? I plan to run 6-7 pounds for now while it is stock and then 10-15 pounds once the engine is built. This is for a weekend car/street car. No track duty at this time. My concern is quick spool and good power.
Thanks.
Old 06-16-2013, 09:12 AM
flsupraguy's Avatar
Update: I'm thinking of twin Borg Warner S256 non extended tip turbos.
http://www.extremepsi.com/store/prod...roductid=21860
http://www.himni-racing.com/turbocha...-56-s256-turbo
What do you guys think?
Old 06-16-2013, 11:21 AM
LS1NOVA's Avatar
Precision 6266 vband turbine inlet and .82 ar. 15psi on the stock engine is just fine. Head studs/bolts and valve springs are the only things you would need for sure.
Old 06-16-2013, 01:11 PM
2000RATA's Avatar
I'd use Turbonetics in light of all the precision failures. And I'd use 6265's with .68 A/R.
Old 06-16-2013, 02:07 PM
fastcars95's Avatar
How much power would you like to make with the built engine ?
You only want to buy turbos once I'm going with turbonetics 6465s for my ls7
Old 06-16-2013, 02:39 PM
Blackpanther99's Avatar
x2 On the turbonetic twins.
Old 06-16-2013, 10:07 PM
flsupraguy's Avatar
Thanks, Im shooting for 500 to 550hp with stock internals and 700ish once the engine is built. My concern is lag on pump gas when Im only running 6 to 7 pounds.
Quick Reply: Smallest T4 Turbos for LS2 Twin Build
