Budget/eBay head studs
#142
As an update Jegs now stocks these and will ship them to you for $100.
http://www.jegs.com/i/Speedmaster/74...FQ4paQodCt0M9w
#146
#147
i use a dremel and cut a groove into an old head bolt. run it in and out with the rattle gun . some brake cleaner to knock the crud loose. blast it with air and vacuum out the goobers.
i use regular moly/graphite assembly lube under the washers and nuts, and cheap 10w30 dino oil on the threads.
#149
i stopped using them when i realized, i was using them for no reason.
still using old- mix match, re used stock head bolts and gaskets in the 740+whp range without issue
#150
Went ahead and ordered some Chinese studs. I figured since it was going to be naturally aspirated and under 500 horse that the cheap studs would work. I may be proven wrong, but time will tell.
The following users liked this post:
Brian Mokrousov (01-28-2020)
#155
I had a machine shop use the Alpers on my 5.3 getting a full rebuild. They used ARP's specs for tightening the nuts... One stud broke the top off and a couple other's bent.
I trashed them and used ARPs.
Really sucks because I hadn't read any issues with Alpers here.
#156
Stress tests have been done on these, they are no stronger than an OEM bolt. The stud is just a better design by nature. No need to reef these things down insane torque amounts. I'm sure 65 ftlb with ARP lube will hold the heads down just fine as long as your tune is good. So will a factory bolt, it just doesn't clamp as well or as even by design.
#157
What did they torque it to?
#160
I also believe I read 65 for the china studs on the ebay AD when I bought them. I went to 70 without issue. (probably doing more harm than good over torquing them to 70 even) 26lbs of boost on an alum 5.3 without an issue.
I believe ARP is 80. And too much for china studs. I went 86 on my ARP's per JFR racing's suggestion.
