Procharger Direct Mounted Filter?
Location: Virginia - Where Rednecks and Presidents Come From
I read a couple threads touching on the idea, but nothing solid....
On the LS1 F-Body's:
Has anyone out there found a "mushroom" type filter that will directly clamp onto the head unit and fit behind the radiator with little or no other mods? I'm planning to run the bypass discharge to the atmosphere, AND I'd like better airflow than the stock Procharger hat.
Please post part numbers and pictures if you have 'em! THANKS!
Here's what I did with the twin intercoolers because the truck hat wouldn't fit... I saw a gain 1.5 #'s of boost.
Procharger supplied filter on the left new filer on the right. http://mycarpics.shutterfly.com/276
K/N # for big filter ^^^ http://www.knfilters.com/search/prod...id=449860&rw=1
Added this little filter for the bypass hole. I had a frost plug in that hole to start. http://mycarpics.shutterfly.com/277
K/N # for the small filter ^^^ http://www.knfilters.com/search/prod...id=449856&rw=1
