Iron 347 street machine!!
Old 12-27-2014, 09:18 AM
  #101
Burken01's Avatar
Originally Posted by josh4ku
I've already been wondering who to have tune it. Thinking speed inc. which would be about 10 hr drive
10 hrs is nothing..
Old 12-27-2014, 10:59 AM
  #102
josh4ku's Avatar
Originally Posted by Burken01
10 hrs is nothing..
No its not if im sure its the best option..which im not.
Old 12-27-2014, 11:30 AM
  #103
JustAFooL's Avatar
Yes second pump was on a Hobbs switch, first pump was run on the racetronix Hotwire kit.
The pumps just have a positive and ground, correct? Use regular wiring to tie them in?
Old 12-27-2014, 11:45 AM
  #104
Burken01's Avatar
Yes, first pump uses the stock wiring Second pump is grounded to chassis, then the power wire goes to a relay.. Then you ground the relay through the hobb switch to chassis ground.. Then connect the relay's last port to 12v Once you go into boost the hobb switch completes the circuit (ground) and then the 12v will turn the pump on
Old 12-27-2014, 04:10 PM
  #105
a-low's Avatar
Was this shop you mentioned the one in
Downey?
Old 12-28-2014, 02:31 PM
  #106
Burken01's Avatar
Originally Posted by a-low
Was this shop you mentioned the one in Downey?
yes, but that tuner they had isn't fit to work in this industry. They got rid of him..
Water under the bridge I'm over it, I have a new car now.. Lesson learned
Old 12-28-2014, 05:11 PM
  #107
JustAFooL's Avatar
What kind of car did you get this round? Plans for it,
Old 12-29-2014, 02:45 PM
  #108
Burken01's Avatar
01 z28
Not sure just yet, maybe stay NA for awhile and enjoy it
I've been thinking about a D1 pro charger for simplicity sake
Quick Reply: Iron 347 street machine!!
