4.8 blow thru , zr1 cam ??
I run with a 5.3 , w/ 2010 ZR1 cam and springs, 950cfm blow thru and a TH350, and I am running 9.40's in the 1/4, and I have not lifted the hood to work on it in 3 mo.
cam
i got one in my ly6 6.0 blow though seems to work good.20" vac at idle. not happy with my diy carb waitng for my csu to get here. no numbers or times but car is fatser then my 10.90@128 vette on 10psi 80mm
Ive got a CSU 750 on my 6.0/squareport/ S480 combo, on gas. I did not have to touch the setup while on the engine dyno, it was bang on. I swaped 2 jet sizes just to see, but it went the wrong way, went back to Kevins tuneup. Worth every cent!
I have only had to increase shooter 1 step up for driveabilty
I have a XER287 in my 313ci (3.905 bore 3.26 stroke) blow thru E85 and it works well 3000rpm on up. Its all in what your trying to do. Id say the ZR1 cam is a good street cam. Mine on the other hand not so much.
CSU has my carb right now as the Quickfuel E85 Blow thru needed some work.
