Gt 4294 big enough?
Old 06-28-2013, 11:05 AM
SILVERBIRD97's Avatar
Default Gt 4294 big enough?
In your professional opinions will a Garret 4294 t4 be big enough for a 370 cu in motor with stock 317s and a cam that will peak around 6800? Looking for around 700 rwhp The specs are as follows:
GT4294
journal bearing
T4 flange
compressor: inducer 70.3 mm
exducer 94 mm
turbine: 82mm
A/R turbine housing 1.28
Old 06-28-2013, 01:46 PM
No one? I am not experienced enough to know what I'm looking at when it comes to a compressor map. I do know there are some 6.0 cars with a turbonetics 7575 in the 700s. Some one educate me LOL The Garrett website says 425-850hp and 2.0-7.0 liter applications.
Old 06-28-2013, 02:06 PM
Jon5212's Avatar
I would think with the A/R that large it may be a little laggy but you are a stalled auto so it shouldn't matter. Sounds pretty good.
Or I could be a smartass and just tell you to go with a 105 thumper.
Old 06-28-2013, 02:14 PM
LOL true. If I had the money and my choice it would be a pt88. But I might have a hell of a deal on the gt 4294. I would think with that AR it should have enough lungs to turn at least 6500 huh?
Old 06-28-2013, 09:30 PM
jridenour31's Avatar
A/r isn't going to allow it to spin that high if the turbine is too small. What's the trim or exducer on the turbine? Also, a 70mm compressor is REALLY small.
Old 06-28-2013, 10:09 PM
o2camaross's Avatar
Are you talking about the one Justin White is selling?
Old 06-28-2013, 10:10 PM
o2camaross's Avatar
IMO, the only lsx I would run that turbo on is a 4.8. It would be a monster on a 4.8 but it's too small for a 370 IMO
Old 06-28-2013, 10:11 PM
o2camaross's Avatar
Unless that 82mm turbine is the exducer and not the inducer then I would run it on a 5.3 too, but the compressor is too small for a 370
Old 06-28-2013, 11:49 PM
topgun542's Avatar
thats my plan
thats the same turbos thats gonna be strapped to my 4.8...
Old 06-29-2013, 12:57 AM
9 Second Truck Club
stock48's Avatar
Too small IMO. A 4202 might do it but pk will be way before 6800, more like 6000~6200.
Old 06-29-2013, 12:42 PM
nutte242's Avatar
I run a gt4294r on my ls1 made 780whp with 14psi and 550 on 7 psi
it has a 1,0ar
Video on the low boost
Old 06-29-2013, 06:00 PM
9 Second Truck Club
stock48's Avatar
it has a 1,0ar
Volvo 242 lsx turbo - YouTube
Sweet build!
What does car trap at what weight? Im around the same with a maxed out S475 and closing in on 160 mph at 3350 lbs.
Old 06-30-2013, 09:49 AM
nutte242's Avatar
[QUOTE=stock48;17511440]Sweet build!
What does car trap at what weight? Im around the same with a maxed out S475 and closing in on 160 mph at 3350 lbs.[/QUOTE
I have only tested it on low boost and it did 130mph the car weights around 3200
Old 06-30-2013, 10:09 PM
vwdave's Avatar
While a tad bit on the small side, I personally see no reason why you cant meet your goals. I would switch to a T6 exhaust housing and a ~1.0 AR on the exhaust.
You can also have the compressor modified to fit a 74mm from a 4202.
Quick Reply: Gt 4294 big enough?
