Stumped, ecm resets in boost.
Old 06-29-2013, 11:10 AM
mike13's Avatar
Default Stumped, ecm resets in boost.
This has me scratching my head.
turbo ls in my 1999 Firehawk
at the track I launch the car it starts pulling building boost and than the ecm does the reset, full gauge swing, trip meter resets, etc looses power and after the reset runs fine, roll back into the throttle and does the same thing.
bad ground maybe? will the coils draw enough electrical power that would create problems if my charging system might be marginal?
Old 06-29-2013, 11:11 AM
mike13's Avatar
Also tried datalogging but when the ecm resets it corrupts the datalog and can't be read.
Old 06-29-2013, 11:16 AM
lurker1978's Avatar
Sounds like a bad ground to me..
Old 06-29-2013, 11:56 AM
LT1RAY's Avatar
Check the grounds on the back of the heads.
Old 06-29-2013, 01:57 PM
mike13's Avatar
just did all the grounds are good, I'm thinking I might be getting a voltage drop when the 2nd 340 fuel pump turns on. It's set to power up in boost. Tried datalogging but when the ecm resets it corrupts the log and won't play.
I'm wondering if the alternator is marginal?
Old 06-29-2013, 02:53 PM
AgFormula02's Avatar
I converted to a one wire alternator which does not require PCM signal to charge. It was upgraded to 160 amps
Had it done for relatively cheap at a local shop
Old 06-29-2013, 03:19 PM
mike13's Avatar
the 105amp alternator upgraded to 160? same alternator?
Old 06-29-2013, 04:44 PM
Johnv's Avatar
disconect the second pump and try a quick pull.
Old 06-29-2013, 04:53 PM
mike13's Avatar
The more I troubleshoot the more I'm leaning towards a marginal alternator. Today it was charging at 14v, yesterday I never saw more than 12v.
Old 06-30-2013, 07:50 AM
Old Geezer's Avatar
"I'm wondering if the alternator is marginal?"...
Time to check/test/verify the integrity of the entire electrical system.
What are you seeing on a data log w/o putting the boost into play?
Does it do the drop out at the same boost level, repeatedly?
Old 06-30-2013, 07:54 AM
nocooler's Avatar
Is the battery secure?
Mine would hit the a/c accumulator and ground out - everything would die and then come back to life.
Old 06-30-2013, 10:32 AM
mike13's Avatar
I agree, spent much of yesterday doing that.
Old 06-30-2013, 10:58 AM
mike13's Avatar
All the battery cables have been replaced this year but spent yesterday checking all the grounds, the ends of all cables, inspected for abrasion or burn damage.
The system was charging at 12v and slightly less in the staging lanes, replaced the alternator and now I see 14v, have to wait a week before heading back to the track.
I think I might get the idiot of the day award, I can't remember if your charging system is always charging at 13.6-14.2? If so it was staring me right in the face.
Old 06-30-2013, 10:11 PM
vwdave's Avatar
Ideally it should be 14.0.
Old 06-30-2013, 11:16 PM
mike13's Avatar
Is that a constant 14.0? With the engine running I should never see 12v?
Old 07-01-2013, 08:17 AM
Ryans99ls1's Avatar
mine did this exact thing when i would hit boost. Motor would twist when it hit peak torque and my catch cans would hit the battery terminal. covered the terminals and moved my catch cans and the problem was gone.
Old 07-01-2013, 12:08 PM
vwdave's Avatar
Should be over 12v. I dont like anything under 13.5 while running.
Old 07-01-2013, 02:03 PM
mike13's Avatar
Ya, I ruled that out right away.
Old 07-01-2013, 02:04 PM
mike13's Avatar
Thanks.
Old 07-02-2013, 07:58 AM
Ryans99ls1's Avatar
I ran around with a bad alternator for a long time. thing almost never charged at 14v. with the lights/fans on the car, it dropped reallllyyy low. Never caused any performance issues until it actually took a ****, but the car suddenly became completely undriveable at that point. It was bucking and surging like no ones business at idle. Its worth a shot to replace yours as electrical problems can be weird but i wouldnt be surprised if its something else.
Quick Reply: Stumped, ecm resets in boost.
