between these two..
Old 06-30-2013, 08:42 PM
ToxicWS6's Avatar
Default between these two..
i have a 5.3L stock short block with epp blower cam, ls7 lifters, 243 heads, ARP head studs, ls9 head gaskets
if you were to recommend one of the these two turbos which would you go for? looking for a quicker spool but dont want to run out up top ether
turbo 1.
Compressor Wheel 70mm
.70 a/r
4” Inlet and 2.5” Compressor Outlet
Inducer- 70.15mm
Exducer- 94mm
Exhaust Side:
Exhaust Housing T-4 Flanged Divided
.68 or 1.0
3.0" Vband outlet
Inducer- 64.5mm
or
turbo 2
Compressor Wheel 76mm
.80 a/r
Inducer- 76.71mm
Exducer- 102.36mm
Exhaust Side:
.96 ar Exhaust Housing
3.0" Vband outlet
Inducer- 74.5mm
Exducer- 65mm
Old 06-30-2013, 09:28 PM
Johnv's Avatar
Turbo 2 for sure
1st one would be okay for a rear mount.
Is it m6 or A4 ? that will also make some difference to recomendations.
Old 06-30-2013, 09:45 PM
slowlsx's Avatar
I have a tc78 with 200 miles on it if interested. This one is upgraded to ball bearing and has 68mm turbine
Old 06-30-2013, 10:53 PM
itsslow98's Avatar
It appears your on a budget so Id go with a turbonetics tc76. If I had to chose though def turbo 2.
Old 07-01-2013, 09:03 AM
ToxicWS6's Avatar
m6 with 3.70 gears, and budget somewhat, ill look into the tc76 though, slowlsx pm me with price plz
Quick Reply: between these two..
