Jet hot 2500 coating
LS1Tech Sponsor
Ive heard good things but never used it myself
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
No pictures. It was not done for looks, I was trying to lower the under hood temps. My truck is just a daily driver that also pulls a trailer once in awhile, not much to look at! I had the dull black top coat, but they can put any finish color on top.
Kurt
Kurt
Yes, I coated the turbo housing. I now have no wrap on any pipes, over the last 10 years (165,000miles) I have used a few different wraps. None of them worked for over 1 year when I was in Michigan, the winter would kill it. The last one I had on (DEI) lasted less than 1 year, it was shredding. I had been towing the mountains a bunch in that time period.
Kurt
Kurt
Kurt
Kurt
Not sure as I cannot measure it. I have wrapped the tubing and Y pipe for most all of the years I have driven this truck. In 2002 when it was new I did not have it wrapped, after about 1 year my coil harness was crispy and it blew a coil driver fuse. I replaced one coil and both harnesses and added wrap. The wrap lasts about one year, but protects my wiring under hood. Now the coating is not covered, and my temps are lower. I always had to wear a glove when checking my oil when towing because the dipstick was to hot to hold. Now I can do it without the gloves. I have a friend at Jet Hot, we have talked about doing some dyno testing while measuring heat. Not sure if we will ever do it, but it's on the wish list.
Kurt
Kurt
Kurt
Kurt
