turbo 347 GTO horsepower estimates.
Old 07-03-2013, 04:19 PM
yelo04goat's Avatar
Default turbo 347 GTO horsepower estimates.
hey guys now that my motor is being wrapped up and things are goin well with getting her back up and running.
i wanna have a little fun. and might turn this is to a game price is right style.
i might even give a prize for the closest without going over.
motor.
forged 347 LS6 bottom end -11cc wiseco pistons eagle rods stock crank
VA speed turbo cam VTC2 23x/22x and .600ish lift.
AFR v2 230 heads 65cc chambers
ls6 intake ported ls1 throttle body
72 lbs @43 psi injectors mast fuel rails
AIS meth kit
Trans on back
newer core 4l80e built to handle 800+
circle D muiltidisk billet verter stalled at about 3200
gforce1320/PTS 3.5 alum driveshaft and full built gforce rear with trutrc and 3.46 gears
Turbo setup.
turbonetics midframe 78mm T4 with 1.14 ar 75mm F1 turbine and big comp over similar to the y2k unit
turbosmart raceport 52mm BOV
turbosmart 60mm wastegate.
will have 2.25 in to 2.5 crossover 4'' downpipe to cutout to 3.5 full exhaust
there will be two power levels to guess and maybe a prize for both
low boost and 91 oct pump gas.. 12 psi... cutout closed
high boost 91+meth 20psi... cutout open
feel free to ask questions and give your guess
Old 07-03-2013, 04:29 PM
stangcobra's Avatar
570 low boost, 750 high boost
Old 07-03-2013, 04:38 PM
yelo04goat's Avatar
oh and if there is more then one person with the same guess the first one to guess that number wins..
ill toss up my guess promise i wont edit it this is more of wht i wanna see
low 610. high 800
Old 07-03-2013, 06:41 PM
b4cz2896's Avatar
Old 07-03-2013, 07:06 PM
Blackpanther99's Avatar
Old 07-03-2013, 07:56 PM
yelo04goat's Avatar
Originally Posted by Blackpanther99
600/850.
your right where i would love for it to be 850 would be amazing
Old 07-03-2013, 08:34 PM
SPRAYED 01's Avatar
Locking Converter on the dyno?
Old 07-03-2013, 09:57 PM
yelo04goat's Avatar
planned on it, yes.
Old 07-04-2013, 12:07 AM
831jd's Avatar
Old 07-04-2013, 03:38 AM
Nitroused383's Avatar
620 on 12lbs and probably some massive detonation with 20lbs on pump gas + meth. You should definitely run some race gas with the high boost setup. 870 with max boost and locked converter. Good luck!
Old 07-04-2013, 06:22 AM
02LS1ram's Avatar
637/822...... What kinda of timing will you Have in it
Old 07-04-2013, 10:21 AM
yelo04goat's Avatar
it will get whatever timing it can take and still be semi safe..
cunningham motorsports will be doing the tuning.
with a proper tune up it will make it to about 20 lbs i think. but after they work their magic and it cant make it there well oh well..
i would like to have a race gas tune up for sure. and there might be one but really it would never get used but maybe a few times a year. ill be driving this as a street car most them time and only turning it up at the trck and most time time it will be on pump gas at the track also..
i feel that as long as theres not detonation LET HER EAT.. and see where she is when she is done i didnt build it to be scared to make power i built it to have fun and hopefully take the 5.7 turbo GTO record.
Old 07-04-2013, 11:42 AM
jridenour31's Avatar
Old 07-05-2013, 11:07 AM
Teamscss.com's Avatar
507 low, 612 high & your motor will blow up on the last pull. So bring aaa card with you. Lol.
Old 07-05-2013, 11:43 AM
willizm's Avatar
535low/720high whp. what dyno?
Old 07-05-2013, 05:28 PM
yelo04goat's Avatar
you sir are crazy... i might need to get with you though about a few things..
did you get the camaro tuned yet?
will be a mustang dyno i believe.. the new shiny one at CMS
Old 07-05-2013, 08:24 PM
LS1NOVA's Avatar
Old 07-05-2013, 09:00 PM
yelo04goat's Avatar
thts not high enough yours dont count...
i kid i kid.. probably pretty close....
Quick Reply: turbo 347 GTO horsepower estimates.
