HELP 80mm Magnum T5 housing to T4 flange
Old 07-08-2013, 04:53 PM
slowlsx's Avatar
Default HELP 80mm Magnum T5 housing to T4 flange
For tye individuals that are running either the magnum or ebay version, how are you guys mating these two?
Called modular turbo and they said to drill the t4 flange but I dont see how that would work. Onoy possible way is to drill the actual T5 turbo housing.
Also the turbo came with a t4 gasket but turbo is a t5
Anyone have suggestions?
Old 07-08-2013, 06:53 PM
redss82's Avatar
i have the ebay one was told it is actually t4i flange all i did was elongated t4 flange holes towards the outside of the flange
Old 07-08-2013, 08:05 PM
slowlsx's Avatar
Did you use t4 gasket?
Old 07-08-2013, 08:33 PM
redss82's Avatar
was planning on using hightemp cooper gasket goo like i used on previous turbo cars
Old 07-09-2013, 08:20 AM
Moderator
denmah's Avatar
i just drilled a t4 out a little and viola
Quick Reply: HELP 80mm Magnum T5 housing to T4 flange
