cut out question???
cut out question???
Anyone knows if somebody made a 5" cutout?
I m doing a 408 turbo Camaro and i like to dump a 5" true the bumper for the track and make a 4" complete exhaust for the street but i need a way to cap the 5" part of the DP. Any ideas that you can have are welcome. Thanks
I ended up making my own flange out of a steel plate with a plasma cutter/ grinder. Bought a sheet of gasket material at napa. Because I couldnt find anything. Good luck. Post up if you find something.
Another cheap easy option would be to pick up a 5" V band cap one end by welding a plate straight accross and put a wing nut on the clamp. Wish I would have went this route as it would have been faster to uncap with there only being 1 bolt to loosen.
