Help need a sleeper cam with no lope
Old 07-10-2013, 12:44 PM
CobraKillingZ's Avatar
Default Help need a sleeper cam with no lope
So I'm new to forced induction just put a F1c procharger on my ls2 based 402, I would like a sleeper cam with almost a stock idle an I'm running on a tight budget so any help would be great. I'm not looking to get a ton of power from the cam, I can always just turn up the boost.
Parts list
6.0 pp heads stage 3 port
1.8 HS roller rockers
M6 stock gear ratios
3.73s in rear
Patriot gold dual springs with titanium retainers so can't go over 6.50 lift
Old 07-10-2013, 01:49 PM
WheelsUp84z's Avatar
Ls9 is a blower cam and can be had cheap from gmpartsdirect.com
Old 07-10-2013, 02:07 PM
How far would that cam go hp wise?
Old 07-10-2013, 02:47 PM
stevieturbo's Avatar
GT9 working fine for me.
There have been people in and around the 1k mark on the Camaro5 forum with the GT9.
No idea what mine makes, but it is quite nippy. It has a totally smooth idle and great driving and power delivery manners.
Old 07-10-2013, 03:40 PM
Ya trying to stay away from replacing the springs and rockers, the gt9 has a crap load of lift. Looking like the ls9 cam is close to my goals I wounder how much power it would make at 15 lbs of boost.
Old 07-10-2013, 04:09 PM
I make about 22psi with my YSi. Perhaps a beefier cam may produce more, but I have no complaints about it.
I did have the EPP 232/240 in before that, but I just wanted something with a super smooth idle, the GT9 seemed to fit the bill.
That said, Tick has a couple of cams I could be tempted by which should also be very mild low down, but less aggressive on the valvetrain than the GT9
Old 07-10-2013, 04:54 PM
quicksilverado's Avatar
Are you looking for a quiet cam for stealth. If so, it will not matter, the F1 will whistle like a ****.
Old 07-10-2013, 04:57 PM
True, my YSi is the loudest part of my motor. I made strives to make the engine quiet, idle smooth and quietish exhaust, and the blower makes a bloody racket ! lol
But the smooth cam did help quieten the blower at idle too. With the chop of the other cam, the gears were far far noisier which cant have been doing the unit any good either.
Old 07-10-2013, 05:14 PM
93camaro_zzz's Avatar
^ What this guy said. lol
Old 07-10-2013, 05:27 PM
No Juice's Avatar
Thats the first thing I thought of as well. You're not going to fool anyone or sneak up on anyone with the F1C, so whats the point
Old 07-10-2013, 08:13 PM
oChristiano's Avatar
Going to need to do Springs regardless.. that F1 will float those valves with out trying on stock springs.
Old 07-10-2013, 10:28 PM
Ya the blower is crazy loud over 2k rpm but below that its not bad that's why I want the sleeper cam so if a cop pulls up my car won't be idling like its camer more like its power steering is going out lol
An I shouldn't get any valve float with the patriot gold dual springs I have
Old 07-10-2013, 10:37 PM
Forcefed86's Avatar
I'm running the $98 zr1 cam on a 5.3. Just trapped 143 at 17lbs. (turbo) Good cam for the cash. Built for a blower motor as well. You need a font pickup on the timing cover and one tooth cam gear. lingenfelter guys pushed well over 1000hp with their version of it.
zr1/ls9 is 211/230 @.050 valve lift and .558/.552 lift with 1.7 rockers and a 122.5 centerline.
If you have the money, the gt2-3 cam would be better from what I've seen first hand on friends cars. It's a great really mild "sleeper" cam.
http://www.lingenfelter.com/mm5/merc...1#.Ud4nwfnqmX8
Still talking about maybe a 10-15hp difference NA, couldn't justify the added price in my junker. I'll just run the cheapo zr1 cam and turn the boost up.
Old 07-10-2013, 10:39 PM
PUNISHER TA's Avatar
Patriot Golds are good to .660... That should cover a lot of cams... How much lift does the GT9 have?
My theory on cam/heads is... unless you plan on maxing out your blower/turbo and/or race in a class, why bother running aftermarket...
Old 07-11-2013, 02:45 AM
GT9 has 656 on the exhaust side. Slightly less on the intake, although the intake also has shorter duration so the ramps would be more aggressive to hit that lift in a shorter time.
I was supplied the 660" patriot gold extreme's or whatever they were called at the time.
So far no problems.
Old 07-11-2013, 07:33 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
You could just go with a used LS6 camshaft. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 07-11-2013, 09:44 AM
71 chevy's Avatar
ultimate sleeper cam, and dirt cheap
dead stock idle lol
Old 07-11-2013, 10:57 AM
Yup I think it's going to be the ls6 thanks bob the 1.8 rocker will help with a little more lift
Old 07-11-2013, 11:21 AM
LS1Tech Sponsor
You're welcome. Bob
__________________
Old 07-11-2013, 12:23 PM
MIGHTYMOUSE's Avatar
Back in early 2003 a little shop by the name Agostino Racing sold me a 'sleeper cam' inside my forged 346 turbo build.
after running a 9.92 at 144 with the 6 speed and 17# boost, and thanking them for how awesome the cam was, having thrown me to the very top of the manual transmission ls1 list; i found out it was my original stock 1998 f body cam.
true story
Quick Reply: Help need a sleeper cam with no lope
