97 Camaro LS1(346) 76MM Turbo Build Thread
#283
So I decided to go air to water. With the crazy hot Summers we have I can't afford to leave anything on the table. My buddy David Farlow(also my fab guy) offered up his PT3000. My air to air intercooler is up for sale on here so check it out if interested.
#292
Thanks man! We have the converter out right now on its way to PTC to get tightened up. It was showing a lot of slipping in the log. It should pick up some good et and mph after the change
#293
Q seems to be less touchy when the IAT's are lower which lends itself to being a good fuel to run with an air to water intercooler. Especially when max power is wanting to be extracted from the combo.
#294
Pulled this from VPs website, they don't recommend Q16 for turbo setups. I know Q16 made my nitrous big block tuneup touchy
-Q16 is highly oxygenated, requiring a 4-6% increase in fuel flow, which will make 3-5% more power than competitive 116 octane fuels. Q16's oxygenation will significantly expand the range of air/fuel ratio acceptability
-C16 is used in turbocharged engines, blown engines and nitrous applications with CRs up to 17:1. Recommended by the top nitrous oxide companies. Spec Fuel for NHRA Comp Eliminator
#295
Entered in our first Ultra race today and first race as a turbo car. We qualified middle pack out of 13 cars. Pretty stoked considering the level of competition we are against. Here is a vid......
#300
That was a 5.50 pass. We are leaving on 8 psi but I have a 1.58 exhaust housing and small cubes so it was making max boost slowly at first, 1.5 seconds. We kept tweaking the tune and got it down to 1.1 seconds. The car is steadily getting faster but the turbo stuff is so new to us that we are just taking baby steps to try an avoid ******* **** up. Hell, well just got the air/fuel in the 11's. We were in the 10's for a while lol
