Oil in water
Old 07-29-2013, 06:16 AM
ezstriper's Avatar
Default Oil in water
Ok, after about 20 runs, found oil in the over flow tank, some water in the valve covers(not much) still was running fine...figured popped a head gasket...brought it home and pulled it down and really don't see anything ??? must be leaking somewhere thru head gaskets I'm thinking(LS9 gaskets) anybody ran into this ? thanks Rob
Old 07-30-2013, 04:40 PM
Wicked69's Avatar
I ran into this and pulled mine. The only one I didnt blow up. Took the entire engine apart and found blown head gasket and one bent rod. I was running 25lbs of boost though and completely stock 180,000 miles.
Quick Reply: Oil in water
