P1sc and new motor ?
Old 08-03-2013, 09:28 AM
jparr's Avatar
Default P1sc and new motor ?
I have a 1998 c5 corvette with a stock motor and a P1SC blower . What are some good combos with this blower as in new motor ? 383 ? 415 ? 370 ? I want forged interns so I can boost more and have more RWHP
Old 08-03-2013, 12:56 PM
JoeMama's GTO's Avatar
I have a forged 9.5:1 370 with a P1 and it puts down 580 to the wheels. The blower is maxed out in terms of RPM at this point and the only way to add power is more compression or a fuel change to run more timing. If you are really only going with a P1 with no intention of upgrading in the future a 370 will fit the bill. If you think a F series may be a possible upgrade go with more cubes.
Old 08-03-2013, 02:32 PM
I8UR4RD's Avatar
you dont necessarily need more cubes for that blower. if you want a 370-408 I would do at a minimum a d1. you SHOULD skip on over to the f1. itll make the same power with less boost and come in sooner and give you more belt wrap since it will most likely be using a larger pulley. good luck.
Old 08-03-2013, 05:43 PM
rwb
rwb's Avatar
Keep in mind that p1 will max out at 725 hp or so. Look into a d1 at a minimum or go to an f1 or larger like an f1x.
Old 08-04-2013, 01:30 AM
I8UR4RD's Avatar
I am not sure if he's quite ready for an F1-x without using a 6 bolt block and going to a cog setup or 12 rib. that thing makes 1000rwhp no problems with plenty left in it.
A lot of these are just guestimates I have based off of countless research of procharged cars. Some can vary depending on fuel and compression and of course overall setup.
A P1 might make 650.
A D1SC can make 700-750 or more depending on the setup
An F1-A usually is good for 800-860rwhp.
F1-C 900rwhp
F1-R---1000 or a little over.
F1-X -----1200-1300 or more.
Old 08-04-2013, 10:49 AM
jparr's Avatar
Okay guys this might help im looking at a LS2 6.0L 680 HP motor .that's why I asked now I can go with a 500 HP motor but I don't want to go anything less. I can send my P1
back and upgrade it to a D1 since the shop I bought it from never told me when I was buying my kit it a was a 200 upgrade , so now I have to shell out 1500 for that ..Not sure if the P1 can be upgraded to an F1 either it be nice thu if it can be ?
Old 08-04-2013, 11:49 AM
Tire Smoking Tranny Blowing Director
Cool28's Avatar
get a f1a and be done with it. That way when you get bored your just a pulley change away from more power .
Old 08-04-2013, 12:37 PM
35thsscamaro02's Avatar
Sell the p1 and get f1a or a used d1
Old 08-09-2013, 07:16 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
If you ordered the ProCharger kit complete with the tune, you couldn't of ordered it with it upgraded to a D-1SC. The D-1SC can only be ordered with the "tuner" kit, which doesn't come with the injectors or tune.
The P-1SC can't be upgraded into an F-1A, they are two totally different blowers. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 08-09-2013, 03:06 PM
Detoxx03's Avatar
Just upgrade the blower. D1SC here on a 376 (LS3) making almost 750 to the wheels and the blower has a lot left in it still.
Old 08-09-2013, 08:32 PM
jparr's Avatar
how much is the upgrade Bob from P1 to D1 ?
Old 08-09-2013, 09:47 PM
LS1Tech Sponsor
http://shop.brutespeed.com/ATI-PC015...PC015A-010.htm
$1399.99 and if you have a six rib pulley set-up you're going to want to swap over to the eight rib and the required balancer, shown here. http://shop.brutespeed.com/ATI-2GP11...-2GP115-08.htm http://shop.brutespeed.com/ATI-Perfo...ATI-917345.htm Bob
__________________
Old 08-09-2013, 09:49 PM
LS1Tech Sponsor
That's what I would do, i would sell the P-1SC or P-1SC-1 and go with an F-1A. Bob
__________________
Quick Reply: P1sc and new motor ?
