**Help with high heat and plug wires**
Old 08-04-2013, 06:38 PM
khenry's Avatar
Default **Help with high heat and plug wires**
My headers aren't wrapped or coated and the heat in the engine bay is insane. It's already taking a toll on plug wires and the boots. What is the best plug wire not only for high heat but also when you snap it onto the spark plugs you have confidence that it really made a good connection? Also what's the best coating for these headers? I'm trying to keep from wrapping them, but if recommended to wrap, what wrap do you suggest. Please answer with personal experience, and thanks!
[IMG][/IMG]
Old 08-06-2013, 12:34 AM
khenry's Avatar
Bump....
Old 08-06-2013, 12:39 AM
willizm's Avatar
mine are swaintech coated and dei titanium wrapped. Nothing under the hood melts now and the temps are much better controlled
Old 08-06-2013, 06:11 AM
ws602's Avatar
Pm me your email and I will send you a few pictures of the work I had Jethot do for me they used their 2000 degree coating and it looks great I will know in a couple of weeks how good they control heat.
Old 08-06-2013, 12:20 PM
gwb1963's Avatar
BBQ Black High heat !!!!! It's like Rocking Chair Red
Cant go WORNG !!! AND YOU KNOW IT !!!!!
Old 08-07-2013, 10:12 AM
Forcefed86's Avatar
Made a simple SS heat shield and mounted it to the lower coil mount bolts. Using cheap autozone Z28 plug wires. They have the correct fittings to snap into place tightly and nice 90 boots on the plug side. They were pleanty long to run around and under the flipped manifold.
Haven't skipped a beat yet currently on 20psi. Plug wires aren't even wrapped.
Old 08-07-2013, 10:27 AM
Mereniuk's Avatar
I sprayed my manifolds in a black high temp coating, then wrapped them. Even wrapped the whole entire hot side as well. still crazy under hood temps, but nothing is melting yet!
Old 08-08-2013, 05:28 AM
LS1NOVA's Avatar
Firecore 50 on the plug wires.
Quick Reply: **Help with high heat and plug wires**
