fuel system for turbo 5.3
Old 08-07-2013, 01:04 AM
dennisgreener's Avatar
Default fuel system for turbo 5.3
Okay, I'm new with all this ls stuff. I've been stone cold lt1 for years and finally making the swap to a turbo 5.3 setup. Going to use stock ls1 intake and I will get aftermarket fuel rails but I'm ready to buy my fuel system and my tuner says magnafuel 750 with 80# injectors which is fine by me but when I looked them up it seems all of that is for an efi setup. I'm wanting to keep it the stock intake. As long as I get the rails will this fuel system work on an otherwise stock setup? I will have it tuned on speed density and my goal is 700rwhp. Any advice on this would be appreciated. Open to ideas.
Old 08-07-2013, 05:02 AM
THADD's Avatar
Kinda confused me a little but you can use the stock intake with aftermarket fuel rails. Then run -8 an line from the pump to the rails with a -6 return line to the tank.
Old 08-07-2013, 05:55 AM
pwrtrip75's Avatar
Originally Posted by dennisgreener
but when I looked them up it seems all of that is for an efi setup. I'm wanting to keep it the stock intake. .
EFI = Electronic Fuel Injection.... in case you missed it.
Quick Reply: fuel system for turbo 5.3
