Billy Briggs-engine break in procedure
Old 08-12-2013, 07:47 AM
eb02z06's Avatar
Default Billy Briggs-engine break in procedure
Install new engine-check
top up fluids-check
add fuel-check
fire it up-check
look for leaks-check
tighten belt-check
All good-then go WOT to 7400 rpm and feed it 26 psi.
Old 08-12-2013, 08:05 AM
TNTramair's Avatar
let'r eat!! ...sounds awsome!
Old 08-12-2013, 08:22 AM
venom ws7's Avatar
Badass
What are you shooting for Arun? Mid 8s with full weight street car
Old 08-12-2013, 10:32 AM
Zmg00camaross's Avatar
Lol break it in like your going to use it I say.
Old 08-12-2013, 12:37 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
I didn't quite go to 7400 on my break in, but did just like you did. Get the fluids in it, prime the fuel pumps, check for leaks, start her up, no leaks, cruise around for 2-5 minutes to get things up to temp, then start doing 1500-4000rpm wot hits on back roads. After 25 miles or so of that, swap the break-in oil and check the filter. All good, swap oil after 200 miles, then I was golden.
Old 08-12-2013, 03:55 PM
94 slow's Avatar
What are the specs on the motor? 364 or 402? Sounds killer.
Old 08-12-2013, 04:43 PM
Firehawk441's Avatar
Billy Briggs.
Old 08-12-2013, 05:42 PM
White.Lightning's Avatar
Your car sounds like a fighter jet getting ready for take off
Old 08-13-2013, 04:36 AM
SSZ
SSZ's Avatar
You should hear it in person. Absolutely awesome. Hope i get to see it at the track this year Arun.
Scotty
Dave Dilucas buddy.
BTW, are you still doing tuning? I am likely gonna need one on my Z28.
Old 08-13-2013, 01:47 PM
ATVracr's Avatar
Car Sounds good!!
Our break in was..... burn out then 400shot.
Next time was ... burn out then 16lbs boost.
Soon to come ... burn out then 25lbs boost.
Billy is the man !
Old 08-13-2013, 04:03 PM
LS1Tech Sponsor
Slowhawk's Avatar
That is pretty much how we break in our motors. Startup, hammer. Never a motor issue. LOL
Quick Reply: Billy Briggs-engine break in procedure
