2002 Trans AM with D1 Procharger
Old 08-17-2013, 03:23 PM
glassmedic's Avatar
Default 2002 Trans AM with D1 Procharger
I have a 2002 Trans AM with a D1 Pro charger with race inter cooler.I would like to relocate my air filter from its current position. The factory air inlet hat with filter is located to low for my likings. Where else can piping be ran to make it safer to drive when it rains and to keep the filter from getting dirty so quick. I am also thinking about just putting a filter directly on the supercharger because the air inlet hat causes a lot of restriction from what I have heard. Anyone with some pictures of there modifications would be greatly appreciated.
Old 08-17-2013, 05:50 PM
SmokedOutZ28's Avatar
Subscribing... Interested in hearing other idea's.
Old 08-17-2013, 09:43 PM
blue05duramax's Avatar
Default Filter
That's funny I'm doing mine right now as we speak with the race intercooler in the front bob from brute speed has a 90 elbow that will go on the procharger I'm using the strainer that procharger has that goes right on the head unit
Old 08-17-2013, 10:15 PM
ramairetransam's Avatar
the best option out there is the truck inlet with a fmic. Other than that its gonna have to be a custom setup . The radiator is in the way and causes trouble.
Old 08-18-2013, 08:39 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
Thanks, I appreciate it. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 08-18-2013, 12:06 PM
dlandsvZ28's Avatar
I routed mine to the front. The stock plastic splash shield cover bolts up with some minor modifications to the plastic cover.
I plan to remove the bumper ends completely. When I do that there will be even more room for the filter. I have an EPP FMIC so I had to cut the center section out of the bumper for the FMIC leaving the ends of the bumper which take a fair amount of room. If removed a nice place to hang a meth pump or transmission cooler.
Filter is a K & N. Just a little shorter but same diameter than the K&N most often used.
Old 08-18-2013, 07:18 PM
DSC_0386 | Flickr - Photo Sharing!
DSC_0383 | Flickr - Photo Sharing!
Are you worried about that flex pipe being sucked shut?
Old 08-19-2013, 06:23 AM
dlandsvZ28's Avatar
It's the flex pipe supplied with the ATI kit. It's wire reinforced. I doubt ATI would supply a hose kit that would collapse. I suppose one could use steel flex tubing as long as you wrapped the steel tubing to keep it from leaking.
Someone asked what the other pipe is for. That's the aluminum piping attached to the outlet side of the charger. That pipe that routes around to the inlet side of the FMIC.
Old 01-10-2014, 12:49 AM
glassmedic's Avatar
Installed a small cone filter directly to supercharger. Fits perfect!
Old 01-10-2014, 12:50 AM
glassmedic's Avatar
No more inlet hat. Less restriction.
Old 01-10-2014, 06:41 AM
do a dyno test to see the difference , you may not be helping yourself .
Old 01-10-2014, 02:10 PM
TNTramair's Avatar
truck intake with a K&n weather protector over the filter...done and done.
Old 01-10-2014, 03:14 PM
namos's Avatar
Exactly this. Truck intake, problem solved.
Old 01-10-2014, 07:04 PM
conor.davis's Avatar
Post a pic! What filter?
Old 01-11-2014, 07:30 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
If you mounted a filter directly onto the procharger, then it's way to small and will restrict your airflow.
Old 01-11-2014, 08:50 AM
LS1Tech Sponsor
I agree! If you have a boost gauge, try removing the filter and make a run in a clean area and see if you don't make more boost. Just be careful as if it makes a lot more boost it could go lean. Bob
__________________
Old 04-09-2014, 07:05 PM
glassmedic's Avatar
Default D1 Procharger air filter on my 2002 Trans AM
Old 04-09-2014, 07:18 PM
glassmedic's Avatar
Works great for me. I hit 10 pounds of boost on a regular basis with this air filter. The procharger hat in my opinion is to close to the impeller. It is like sucking air against a wall and has to pull air in from the side of the hat. Now the filter is direct!
Old 04-09-2014, 08:40 PM
UNDER PRESSURE MOD
I would be extremely surprised if that filter wasn't a huge restriction compared to the truck inlet with a large filter.
But if you are satisfied, that's all that matters.
Quick Reply: 2002 Trans AM with D1 Procharger
