procharged trans am results
Went to the dyno this week after i could only get 5psi out of my bad intercooler.
5psi i was at 460.
347 9:3.1
Wiseco pistons
Eagle rods
Vrx5 cam 236/238
Milled 317 heads
Hooker 1 3/4
Magnaflow catback
60lb injectors/ aero 340 pump
D1sc 4" pulley
Fmic
Stock bracket
4l80
3200 5 disk
Moser 12 bolt 3.73
End of the day i left with 580/481 @ 12psi.
Car feels strong was hoping to get 600 n more tq but is what it is.
Maybe ill drop a pulley size an do poor man belt wrap
__________________
5psi i was at 460.
347 9:3.1
Wiseco pistons
Eagle rods
Vrx5 cam 236/238
Milled 317 heads
Hooker 1 3/4
Magnaflow catback
D1sc 4" pulley
Fmic
Stock bracket
4l80
3200 5 disk
Moser 12 bolt 3.73
__________________
cant compare boost to another motor, cubic inch, cylinder head, and cam variances will all play a part in effective boost numbers......the car is well safe at 580rwhp and through an unlocked 4l80e with mild parts its not bad, keep in mind its taking 60+hp to spin that blower at that speed.....dyno's a tuning tool only we race cars not dynos, take it to the track I may go this weekend mike if I can get my **** fixed........as for the tq number its a converter that was unlocked on a chassis dyno, there was slippage in the converter not to mention your still only 347 cubes with a decent sized cam
UNDER PRESSURE MOD
To your point, if he's got it setup as a track car, and gets the results he's looking for at the track, who cares what the dyno numbers are.
do you think the 3.73 will be too much or are you going to run 28" tires.Also I'm running a 4.38 pulley and see close to 10psi-11psi.
so far my best is 450 rwhp but belt was slipping at 8 psi and the accy belt broke now I have a katech tensioner .
No track times as of yet till I get the belt issue fixed and better tune.
