Aem tru boost help
Old 08-29-2013, 03:34 PM
huggerorange69's Avatar
Default Aem tru boost help
I have a 4.8 with a 76mm turbo. I'm using a 50mm emusa wastegate. I took one of the springs out. I've got a aem tru boost controller. I want to set it at 15-16 psi. What the hell do I need to do to get this thing to work. What does my waste gate crack pressure need to be at? And what does my duty cycle need to be at? Just give me a ball park or something. The car goes straight to 20-22 psi everytime.
Old 08-29-2013, 04:35 PM
Twin turbo c5's Avatar
You'll have to play with it a bit but mine is set at 49 and I have about 18 psi with a 12 psi spring in the gate. I usually set my crack pressure at around 5 psi. But some do different mine has a tendency to osculate if I set the crack pressure high.
Old 08-29-2013, 05:04 PM
Nothing I do makes a difference. I checked the wastegate and you can see where it has been opening because of the Blackness of it but I need to figured out how to get it down. I have no clue what size spring is in my wastegate. It didnt come with any papers saying what they were.
Old 08-29-2013, 06:48 PM
dudeman's Avatar
how much does it make with the boost controller turned off?
Old 08-29-2013, 07:04 PM
I plugged off the lines today and it ran it without the tru boost and it was the same
Old 08-29-2013, 07:55 PM
redss82's Avatar
So your not running any pressure to the wategate? Should run a line directly to the bottom of the wastegate from the turbo that will get lowest pressure out of the spring
Old 08-29-2013, 09:52 PM
I have a line to the bottom of the wastegate. Do I need a line to the top? Or what goes there?
Old 08-29-2013, 10:49 PM
Moderator
denmah's Avatar
there are two ways to run the Tru boost
adding pressure to the top, and restricting pressure to the bottom of a 2 port wastgate setup.
each way uses different ports on the wastegate and solenoid supplied with the controller.
there is three boost settings on the gauge, OFF / A duty / B duty
OFF is wastegate pressure
A duty is whatever you set it to, start off with 25% and see what that gets you...
hypithetically speaking, if you have a 10lb wastegate, close to 50% should add another 5PSI and 90% should add another 10lbs.
in a perfect world.
Old 08-29-2013, 11:29 PM
in a perfect world.
Ok that makes some sense. I will give it a try. Thanks
Old 08-30-2013, 12:08 AM
Moderator
denmah's Avatar
set spring to lowest or zero for now, to rule out any issues with that.
i usually set it up to just restrict makes it easy one line to the bottom of the gate, and the solenoid in between, but it has to be the normally open port diagram
Old 08-30-2013, 10:07 AM
jrpimp00's Avatar
http://www.aemelectronics.com/Images...%2030-4350.pdf
Id use the lightest spring you have and set the crack pressure to 3-5 psi
Quick Reply: Aem tru boost help
